Poll: Canadian Grand Prix 2022, Montreal - Race 9
Rate the 2022 Canadian Grand Prix out of ten
  • Total voters
    95
  • Poll closed .
Status
Not open for further replies.
A statement from the FIA read: “A Technical Directive has been issued to give guidance to the teams about the measures the FIA intends to take to tackle the problem. These include:
“1. Closer scrutiny of the planks and skids, both in terms of their design and the observed wear
“2. The definition of a metric, based on the car’s vertical acceleration, that will give a quantitative limit for acceptable level of vertical oscillations. The exact mathematical formula for this metric is still being analysed by the FIA, and the Formula 1 teams have been invited to contribute to this process.
“In addition to these short-term measures, the FIA will convene a technical meeting with the Teams in order to define measures that will reduce the propensity of cars to exhibit such phenomena in the medium term.”
Seen as Horner was so unnecessarily blunt about these issues (hey Christian, not every plays the 'game' as much as RB obviously do) I'd love it if they were found to be doing something they shouldn't be to limit their own porpoising.
On the other hand, if the RBR car is legit and all the other teams have to increase their ride height to adhere to this new metric, RBR are going to run away with it.
I could take Merc being **** a little bit better if it was any other team than Redbull that was dominating. :D
Just read that they will sort out the appropriate something before fp3 and if you don't comply its a 10mm ride height increase of you fail to comply after that its disqualification.
Which I think the is fair even if rb win everything. At least it will force merc to sort their ****box out (totos description)
Does the RB actually have a higher ride height though ? Honestly it’s such a complex argument I don’t know.
They've certainly been the masters of high rake going back to Vettel's driver championships, something which threw Mercedes at least a bit last year, when the new regs came in.
FIA have a duty to respect the drivers health. The teams should be doing the same, not wait for the ruling that has now been implemented.
I think it's pretty harsh to be punishing all teams for this. Mercedes are suffering worse, and definitely are "playing the game".
Hope we don't see any specific team run away with it now.
Edit: Would a higher ride height have any effect on how close the cars could run to each other?
The teams that are not suffering will not be affected by the rule change.
Merc etc may well suffer more as their performance will drop.
Its up to them to sort out the issue as higher ride height will bring lower performance issues.
I don’t think we should see it as “punishing” anyone. 99% of the drivers have basically said it’s unacceptable as it is. If they’ve not it’s because they’re winning e.g. Ferrari and RB. Go look at the Leclerc helmet cam from Baku. It’s insane.
This, RB will benefit, Mercedes attempts to pressure the FIA into making changes will backfire on them...
They had the advantage of having someone from the last era (with practical experience) of ground effects to design the car.
Well, it'll reduce the efficiency of the ground effect design and mean that the bodywork and wings are back to providing most of the downforce so I'd say yes.
Shouldn't make much if any difference in terms of how close cars can follow - it shouldn't affect how the bodywork and wings generate downforce (and the cleaned up "wake" they generate), but will obviously impact how much downforce a car can generate (meaning more sliding around, and potentially more tyre wear for those affected)
Status
