TBH Nvidia could have been dropping 3080FE's for a while now, but instead they started dropping newer versions of the GA102, bit more RAM, new more cores, huge price jump, that's not scalpers or miners fault, that's nvidia trying to profiteer from the sector..
People can roll the dice, buy a 2nd hand RTX 3080. I reckon the LHR cards will be a better bet, due to being released later and they are less likely to have been worn out by mining.
3080FE LHR doesn't existDepends on the cost of the second hand card, prices still arent great so you might be better off buying new and then getting the warranty etc.
I've yet to see any direct tests between the 3080FE and the 3080FE LHR, what else could/does the LHR side of things effect..
I've actually had 3080 that was used for mining for around 1 year did benchmarks /temps noted them down
After re did the benchmarks and it's exactly the same with scores and temps hasn't had any effect
I would hope people who mined looked after them by using optimized settings and in good ambient environment
Wow… the unicorn (3080) is coming out to play more often haha.
Option one, do it! YOLO. Never wait get what you want when you want.Amazing to see it still in stock. Should I shouldn't I....
Do you mean that perhaps they assigned a lot of their remaining RTX 3080 GPU dies to FEs, to ensure they are sold before the release of the new series?3080 still in stock after a couple of hours, new cards must be due to release very soon.
Return it and grab a FE card!Don't suppose CEX would let me take back my EVGA RTX 3080 now, it's been 4 days since I received it...
C'est la vie.
Seems like the market is (finally) improving though, looking on the bright side.
I really thought we wouldn't see any more RTX 3080 FEs, after waiting for months.
You have 14 days to return an online purchase even from said retailer. You can go into any store and return it. Return it and get the new 3080.Don't suppose CEX would let me take back my EVGA RTX 3080 now, it's been 4 days since I received it...
C'est la vie.
