I am bothered about that, I like to watch the pool.I know a few people who are more bothered about the loss of Freesport channel.
@Blackjack Davy - Not everyone can have a satellite dish / blocked line of sight to the satellite.
BBC News HD no longer available on Freeview from 30th June 2022
Channel Changes and closures on Freeview on 29th & 30th June
On 29th & 30th June 2022 there are changes being made to the way some channels are currently broadcast.www.freeview.co.uk
Options:
- watch the SD channel (lol no)
- use iPlayer
- stop watching BBC News
I'm very surprised that a main channel would just die off like this. Gonna pee off a lot of people.
And that is exactly what has happened. BT has upgraded its core routers to support multicast.This is basically the challenge: broadcast TV signal reaches most but not all of the population. For some it's a reduced service i.e. fewer channels, and for some it's flaky, and for some they're out of range.
Same for broadband except it's something like 10+% of households, and there's doesn't seem much plan to remedy this.
IMO broadband should be as available and reliable as mains electricity and running water at this stage. It's a basic right of access here.
On the bandwidth topic relating to internet TV - there's something like 5-7 multiplexes running, each carrying let's say ballpark 20Mbps of content. That's easily 100Mbps of information in the airwaves right now bouncing off your walls and through your skin. Arguably that bandwidth would need to reach every home over IP to match efficiency. If everyone were to individually stream content (rather than taking it from a broadcast or multicast) the internet traffic wouldn't cope. So we do need a properly engineered IP TV infrastructure to make this work.
Or just shut the things down must be costing a fortune all those transmitters all over the country when a single satellite gets the job done my father can even pick up the service in Spain albeit with a larger dish
The problem is broadcast. IP has so much routing overhead that it isn't practical. I think 5G had partially solved this.I think fibre optics and IPTV is the future. If they do this then 4K TV channels should be pretty trivial.
News to me too!It is? That’s news to me. I know it’s a bit crap but to actually bin it? Can’t see that happening as there are plenty of people without Sky and internet that like to watch TV
I only use freeview and already I miss both the HD BBC News channel and BBC4 too.That's cos it's not true.News to me too!I only use freeview and already I miss both the HD BBC News channel and BBC4 too.
More importantly CBeebies HD has gone!
Should be moving to 4k not moving back to SD
All broadcasters should be looking at transmitting in 4k and no removing HD for SD should they not?How do you think the 5G basestations link back to the cellular network? Each network operator will be building a new fibreoptic backbone or greatly extending the ones they built for 3G/4G. Base station traffic capacity exceeded what commercial microwave links could carry back in the 3G days (particularly after HSDPA rollout on multi-frequency cells).The problem is broadcast. IP has so much routing overhead that it isn't practical. I think 5G had partially solved this.
Why?Why?All broadcasters should be looking at transmitting in 4k and no removing HD for SD should they not?
What’s the difference in production costs / cameras though? I would guess not much beyond more data storage needed and assuming you’re not buying RED movie cameras.Why?
A huge proportion of content that goes on TV isn't even filmed/produced in 4k. It's just not needed for the news, or serials like EastEnders. Do you honestly think that cartoons and kids shows need to be 4k, and kids will notice/care?
I get frustrated with some of the lower quality SD channels (yes compression and quality are variable on SD broadcast in order to preserve bandwidth for "more important" services). But most of what's on normal TV either doesn't need to be mega quality, or isn't available beyond HD even at source.
I agree that 4K isnt needed for news or cartoons but Im sure news broadcasts have had the equipment for years to record in 4K. As for cartoons, they are all done on computers now so its easy for them to renderer at 4k if needed. But this move is a step backwards going back to SD.Why?
