Any recommendations?Air tight jar for short term (daily) and vacuum for long term (excess from a large bag)
I've seen atmos are a good brand and airscape
Nope, it was mid way through grinding a load of beans and it just seized up. I've seen that video already and have been trying the foil method, it's just so tedious and after a couple hours it still isn't shimmed properly. I guess I just need a bit more patience..There's a chance they have been knocked out of wack slightly when they seized (were you adjusting without the grinder running by any chance?)
that or the clever dripper, I got given a fortnum and mason hamper with a load of coffee recently and been running it through the clever, I do like the immersion methods with a filter & the hario switch seems a good optionJust ordered a Hario Switch Brewer...best all-rounder combining a steep and filter all-on-one?
you'll get a much better grinder going separate, the smart is OK, good design from a user point of view and a good price. Might be worth looking at the Eureka Mignon Manuale, less features and a bit more, but a much better burr and less plastic overall.So naturally I have been looking at the Sage Smart Grinder Pro, I'd just like to check this is a half decent idea though as opposed to selling the Bambino and buying a Barista Express... I talked myself out of the BE though due to the grinder supposedly letting it down a little.
My clever dripper broke after about a year.
just checked and mine is 10 years old! The seal leaks a little sometimes so was thinking about replacing it, hope the new ones aren't cheaply made - the Hario is quite a lot more but will wait @Raymond Lin 's reportMy clever dripper broke after about a year.
Mines physicsally snapped iirc, been years now.just checked and mine is 10 years old! The seal leaks a little sometimes so was thinking about replacing it, hope the new ones aren't cheaply made - the Hario is quite a lot more but will wait @Raymond Lin 's report
