Based on my "own" testing, yes, it fits exactly what hu, tpu, df, gamers nexus, oc3d have shown with their testing.So you do believe DLSS is "Better than native image quality" ?
In a number of cases based on personal experience, I'd say DLSS has very little negative impact on image quality, especially in actual gameplay as opposed to screenshots. Bear in mind that I will tend to use the highest quality DLSS available, ymmv with lower levels of it.
However, it's a tool I'd apply to improve framerate, not image quality. If I was already pushing my monitor's max rate, I wouldn't apply it.
I find dlss now to be superior in motion compared to native/taa (which was its weakest point prior to 2.3 or 2.2 iirc)If you get 4k 60, FPS max settings in a game and it sticks with no drops or 1440p 120 FPS rock solid, what purpose does dlss serve
Some people buy a GPU and keep it for 5+ years.
Heh.. my GPU is coming up to 6 years.. but I would have replaced it before now had the dark ages not happened.I guarantee they are not the ones activelystirringposting on here!![]()
If a GPU does 120FPS at 1440p then DLSS isn't needed at the moment but it's a nice feature to have for future games. Some people buy a GPU and keep it for 5+ years.
This sounds all so familiar eh @tommybhoy
Prefer native myself.So you do believe DLSS is "Better than native image quality" ?
Absolute blasphemy, turns things down....are you mad lmao. I will do no such thing, I'm PC master race.But you do know you can turn those settings down @TonyTurbo78 ?![]()
Absolutely, that's what it's all about, although sometimes it only gets to nearly full on max with an 3080I've got a 3090 and I still love a bit of DLSS, it means I can smash on all those bells and whistles to full on max and gain what I would have lost if I wasn't using DLSS in doing so.
Regarding if it looks better than native, it's certainly no worse and gains fps, what's not to love.
, however, when I turn off DLSS/FSR just to compare with native- native wins, I'm just going off what my own eyes are showing me, but I don't watch a lot of tech sites.
The ones that go for the actual high end GPUs tend to be more active on upgrade cycles then those from lower end gpus.
My further point is, people who go for high end hardware don't want to compromise.
Ok that's you, that's fine if you do that, but plenty of others that upgrade on a shorter cycleThat's not true, in my case I buy the best that I need at the time and keep it as long as possible because sometimes I may need a VRAM update or more performance, reality is I use to update every year or two and that was the days when we got real upgrades not the 20-30% gen on gen we have had for a while now, since that I went from the year to two years upgrade cycle to every other gen so 4-6 years normally upgrade cycles and that started on the Nvidia gtx580 time, from 580 I went 780ti for a few months then got a 980ti to now dual 3090's and will not be upgrading till 5000 or 6000 series nvidia if they are worth the upgrade then if not I will not be moving from the 3090s.
I like to buy the best at the time of purchase to stop the none stop upgrading for little increases that are not here or there normally, in the past I enjoyed that when we got real upgrades, now it's nothing but a waste of time, waste of money and headaches with the gremlins in the new tech for first few months to a year and I just want a system to work now without the headaches and only upgrade normally when any gremlins have been removed too. The new tech bugs and driver issues gets old very quickly at my age now and don't have the patience I once had for it and the time.
Because of physics? Don't think there is an enough powerful hardware for that to do it a massive scale. For geometry is Nanite.That said, I'm waiting for the industry to rediscover voxels and put some resources on optimisation, that would be a technology with real gameplay impacts instead of just visual...
