It's fine if you're immune to acid. Further they're supposed to be nearly invisible, aren't they?
Spot on. From memory you needed to have high wisdom and throw a high dice in order to even notice that its there in the square next to you. So perfect logically that in that clip they are dodging away from a charging monster and leap accidently into the cube.
You can make saving rolls to get yourself out of the cube or can be pulled out by another player (after taking damage of course)
