no idea, if my wheels where like that i would go to a alloy wheel repair specialist
I don't fancy paying £100 just to repair one small scratch
More freakin sand in the rain last night....when will it end!Another 3-4 hours I will have to spend washing it all off by hand to avoid any scratches.........
www.cleanyourcar.co.uk
Soft 99 - Glaco Glass Polish Compound
Soft99 Glaco Glass Compound – Effortless Glass Deep Cleaning Restore crystal-clear visibility with Soft99 Glaco Glass Compound Roll On, the ultimate glass polishing solution designed to remove stubborn contaminants, old coatings, and water spots. Featuring a unique integrated felt applicatorwww.cleanyourcar.co.uk
This is good stuff.
I’ve got Bilt hamber currently but used Meguires in the past. Tbh clay is clay just get something that is cheap, you’ll eventually throw it anyway.
Sure.hmm, well im not sure, can you paste some links for clay please ? Thanks
cheers !
No problem. I’ve used a mitt in the past as well, not sure how they compare to a bar but they do make it a much quicker job.cheers !
Bit hard for me mate I live in a flat about 100ft from the nearest taps to car! Too low pressure to use a machine have to do it all by hand! Also the car already has a factory finish Gard-X liquid ceramic coating not sure I can put anything else on top of that!A super runny snow foam should really help get it off
Then use a wax or liquid crystal so that the paintwork is extra smooth next time - makes it even easier
So I've used both that and the Ultra Glaco. The latter is like RainX but better, less wiper judder. Forensic Detailing did a vid on them a while back.i saw that from a video i watched just yesterday from Pan the Organizer its great stuff by the looks of it
i think that's the protection part, but i still need to clay it first though
tbh i need a glass sealant anyway, the one i have is a rinse with water to activate (bodywork and glass) but i want to not have to dry the glass etc. afterwards if I'm just doing the glass
EDIT// i was thinking of their Roll on , not the above
i do have autoglym glass polish , will this do the same job as claying the glass ?
