*** The Car Cleaning Thread ***
Status
Not open for further replies.
I'd be interested if a smart repair is available as annoyingly I've got a 3mm glitch on my diamond cut bit. Not enough to warrant a full refurb tho...
More freakin sand in the rain last night....when will it end! :mad: Another 3-4 hours I will have to spend washing it all off by hand to avoid any scratches.........:(
A super runny snow foam should really help get it off :)
Then use a wax or liquid crystal so that the paintwork is extra smooth next time - makes it even easier
I have never decontaminated my car or cars glass before
car is now 8 years in my possession (but car is much older than 8 years!)
can you recommend me a clay bar for the glass and another for bodywork or do i just use the same one ?
i looked on in2detailing and they have 3 different grades, so im unsure what to buy or where to buy
i certainly want to do my windscreen, the bodywork im not too bothered about on this car
This is good stuff.
I’ve got Bilt hamber currently but used Meguires in the past. Tbh clay is clay just get something that is cheap, you’ll eventually throw it anyway.
This is good stuff.
i saw that from a video i watched just yesterday from Pan the Organizer its great stuff by the looks of it
i think that's the protection part, but i still need to clay it first though
tbh i need a glass sealant anyway, the one i have is a rinse with water to activate (bodywork and glass) but i want to not have to dry the glass etc. afterwards if I'm just doing the glass
EDIT// i was thinking of their Roll on , not the above
i do have autoglym glass polish , will this do the same job as claying the glass ?
hmm, well im not sure, can you paste some links for clay please ? Thanks
Sure.
No problem. I’ve used a mitt in the past as well, not sure how they compare to a bar but they do make it a much quicker job.
Bit hard for me mate I live in a flat about 100ft from the nearest taps to car! Too low pressure to use a machine have to do it all by hand! Also the car already has a factory finish Gard-X liquid ceramic coating not sure I can put anything else on top of that!
well, i just used this https://www.in2detailing.co.uk/products/carbon-collective-hydro-portable-battery-sprayer with BH autofoam then rinsed off (i have a portable pressure washer, but a hand sprayer will do)
i do have these 2 which ive never used (polish probably once)
So I've used both that and the Ultra Glaco. The latter is like RainX but better, less wiper judder. Forensic Detailing did a vid on them a while back.
Finally, been waiting for it to cool down before cleaning the car.
Used a couple of new products today, with mixed results.
CarScope Rotor wheel shampoo - didn't feel as slick as Garage Therapy's wheel shampoo and it didn't seem to foam well in the foamer. Although not sure if that's down to the Carbon Collective Hydro+ foamer, which I was using for the first time.
CarScope Siege - this stuff just shouldn't be for sale. This basically smells like that cleaning liquid you get in those oven cleaning kits where you place your racks in the zip lock bags. It also burns your skin just as badly! It's very gel like and despite holding the bottle far from the tyre, the stream like gel spray kept bouncing back off the tyre and onto my wrists/arms where my gloves were not covering.
Carbon Collective Hydro+ - was nice not having to pump but foam consistency wasn't great, but as I mentioned before, that could be down to the new wheel shampoo I was using.
Koch Chemie FSE - Really liked this stuff, I've had bad water spotting in my door jambs, cleaned them up with some CarPro descale I was using on the rest of the car body with a brush and finished off with FSE. Topped the rest of the car with it as I was impressed with the gloss.
Status
