Similar to mineHow does this look guys? 5800x 4.6 all cores RTX 3070 stock https://ibb.co/NWGp2qM
(3700X and 3070 both at stock), though not sure why my minimum frames are so low.
Similar to mine(3700X and 3070 both at stock), though not sure why my minimum frames are so low.
Might try some undervolting.
Edit - better on the second run.....
Edit - undervolt + small OC on the 3070 (1900 + 800)
Edit - had to bring the core to around 1950 and left the memory at +800, was getting artifacts with anything higher. But still - a 5% jump and 5-10 degrees lower ain't bad for minimal effort.
