The proposed reason for why Nvidia doesn't want to implement FSR themselves goes straight out the window when you remember gameworks exists. Nvidia uses gameworks to knee cap AMD and their own old cards and they don't care about the backlash regarding that. Why would this be any different?People are making it out like nvidia is going to dictate how and what intel and amd can do with their own solutions when from my understanding of streamline, they will have no say whatsoever, again, it is just a framework to allow seamless integration of all 3 in one go as opposed to the current method developers are having to face of implementing them all (well less so intels one....).
Guessing you're skimming posts again?
That has already been raised by someone else but for reasons, it's not the wisest decision for nvidia:
IMO, that is the last reason nvidia want streamline to be successful, dlss is already integrated into several game engines to allow quick and easy implementation in games (as attested to by developers), from nvidias POV, the most applicable reason is to ensure dlss stays around for much longer as eventually there will be an "industry" standard, most likely in DX or/and vulkan itself.
All in all, I find it hilarious this:
"nvidia are bad because they don't do any open source solutions"
*nvidia make an open source solution to aid all gamers and developers*
Insert new reason to hate on nvidia. I swear if nvidia made dlss open source and able to run on all hardware, people would still find some reason to hate on them.
No one has been able to provide a good/solid answer to this yet.
If only FSR 2 was here 2-3 years ago and in the same quantity and quality of games.....
Yep still skimming posts. Most posts have too much waffle anyway
From a technical point of view, isn't streamline a middle man between the render engine and say FSR or DLSS? Isn't the advantage of FSRs open source nature that developers can choose how to integrate it into their pipeline? So streamline removes one of the advantages of FSR.
Also from the little I know about programming I thought middle men reduce the performance of programs. So a clean integration of FSR would perform better than one that needs to run through streamline.
Assuming what I have said is correct then,the only advantage of streamline is to keep DLSS relevant for longer and there is no benefit to the end user.
