The gap at the top and the bottom of the case is not identical - so two identical rads looks more out of place to me. Hence why I went one 40 and one 60mm thick rads.
Good shout, didn't consider this.
Decided to ditch my EVO.
Planned for a triple rad setup, but because of the size of the GPU block (https://www.overclockers.co.uk/ek-w...d-rgb-water-block-nickel-plexi-wc-a9f-ek.html), I wouldn't be able to fit the pump/reservoir combo.
The flat version of the reservoir may have worked, but considering how close the GPU block was to the glass (barely a sheet of paper, if not touching it).
Personally, even with the upright GPU kit, the inverted mode seems odd to my eyes.
Depending on the GPU you're using, you may have some more flexibility, but for a standard orientation case, I would choose the O11 XL any day.
I don't really like the Evo's bottom filters.
The only advantage for my use was the possibility of front intake/mesh, but that should've been included in the case as standard.
I considered the XL after realising that my PC wont even be on my desk as I don't have room and therefore wont get to appreciate the aesthetics. I think I'll get a little side table to put it on,but then the wires will annoy me. Can't win.
What made you switch?
You mean long ways top to bottom? Then no. Only EVO.
I have the enthoo 719
It's definitely a FULL tower
Had to put wheels on mine as when fully loaded
It's severely heavy
