Run in max priority from task manager if you want consistent results. Otherwise it depends on whats running on the background taking up resources. A 12900k should score 27800 roundabout on max priority.Just out of interest, how does the scoring work on this? I ran another test today, almost identical apart from faster pump settings, but today I scored 26350, vs 27464 previously. Perhaps slightly warmer ambient today. But otherwise identical set up. Cheers.
I think its just time taken to render the passes.Ok thanks @Bencher i was using High priority, will try Real-time. When generating a score, what does cinebemch take into account other that time taken to render the passes inside the 10 minute window? Does it factor for temperatures, power usage, utilisation, etc? Other that what’s on the Maxon website, I couldn’t seem to find anything on the net that explains this in detail.
Throttling? I get 30k at 5.1 ghz12900K all core 5.2
Multi 29089
Single @ 5.4 2103
Never saw any dips during the run. Maybe you had TVB enabled ?Throttling? I get 30k at 5.1 ghz
OK, using the Dinos22 guide for OCing the 12900k (), I got 29409 on Multi Core, and 'only' got to 92 degrees on the CPU, on a watercooled system (due to two cores pushing into the 90s). I don't yet know about how throttling may or may not be involved here. Or how to correlate the fact that HWMonitor reports 5.4ghz on some of the cores, whereas @momo56 you report 30K at 5.1ghz? I ran this at 'realtime' priorty setting for Cinebench, but there were a couple of things running in background (norton, malwarebytes, etc).
