Energy Prices (Strictly NO referrals!)
so my battery is 7.2 kWh total however usable amount is 6kwh (the system shuts it off at 20%. I can over ride it but will then lose my 5 year bonus warranty. (it's 10 year warranty total but only half is from manufacturer).
right now I use maybe 2kwh of the battery.......my settings - which are better for winter really not summer but as I said it's a faff to change....
during the day I run off solar and any excess charges the battery. only then do I sell to the grid if solar doesn't cover all my use then the battery supplements it. I have not used any grid power on "peak" times since late April.
at 9:30 the house flips over to the grid where I get cheap energy .... now my battery charges - at moment it is only 1 or 2 kWh to top it off then the house runs off the grid til 1:25am. (at 1:30 my cheap energy ends) . at that point it's back over to battery. I am in bed by then so our house base load is on average not more than 200wh. by 5:30 the sun is rising again and I am back on solar and by 7am the battery is topped off again. like I said I could work this more more efficiently ifni had access to my settings...... at most the battery will have used 2kwh then rinse and repeat .
in winter it's much more interesting as my home office needs electric heating. instead of using a. heater however I bitcoin mine 24/7 which means I don't need a heater. this winter however I may not but that is another thread.
but I make full use of the battery then. unfortunately I do still need the grid.on peak as well but even so it takes off a massive chunk.. over the year way less than 10% of my energy used is peak price from the grid
edit the battery can only output max of iirc 3.5kw.so if no solar I do still sip some from the grid from time to time (cooking tea perhaps at night) but according to my app it's negligible and does not really count for anything.
I got back from my hols yesterday and the washer and tumble drier (heat pump so is efficient but slow) has been on literally all day (still going now with 20 mins to go) on load number 4 I think in the drier and load 6 in the washer. and the wife is cooking a curry for 10 meals as well as tea for the little one. battery is still at 80% however and nothing from the grid.
(sorry for wall of text.tldr however it's a no brainer if you can afford it and not planning on moving for a while)
No its great to hear your experience with the batteries and such which is great and I'm glad its working out for you :) I'm looking to move at some point but maybe not so much right now??.....
If I had a battery system with the solar, I'd like to be almost 90% off grid power if I could be. My usage from say 6 till 6am isn't much but with a 10kW battery or something I'd like to think that would cover anything I'd use around the house till the next morning.
The only thing really that I'm concerned about is that when in the winter months when the solar is low and sometimes not even a 0.5kW has been made, how would it be then with a 10kW battery to recharge.. (Just for arguments sake..) My overnight usage is not much, so over a year at worst case I'd have to work out the numbers but I wonder how long it would take to re-coup the costs.
I did Google how long batteries lasted for solar and that was about 2000 recharges and between 5 to 15 years.. Which I believe they quoted the Lithium ION batteries as well as acid batteries where mentioned but they had half the recharging capabilities.
I'd like to consider possibly another set of panels on the front of the house if that would make any great differences and possibly batteries too but I think that might be just wasting cash over what I have really. Unless I've got the AC running most of the day, I do wonder if the batteries would be a viable option for right now for me :)
Its practically impossible to go solar only off grid in the UK.
To go offgrid you need most of four things, possibly all combined
1) A really massive array, as you say winter generation can be down to a very low % of theoretical array size
2) Off grid power generation, so a petrol/diesel generator is most usable, which is what most offgriders have
3) A will to be very low usage potentially for some time, ie just enough to survive, no loads of washing and tumbling if generation is a trickle
4) An alternate source of warmth, log burner, coal fire etc
Modern batteries are now typically 5000+ cycles over 10 years warranty (or more cycles (more is pretty much irrelevant))
Eg https://batteryfactory.co.uk/products/givenergy-9-5kwh-li-ion-battery
They use LiPo4 now
If you can get on a cheap off peak tariff (Octopus by far the best in market right now) then you can charge for less than 10p per unit over night.
If your battery gives you somewhere like 70% plus of your daily usage even in winter you will have days with grid independence, but not many.
Spring / Autumn you will likely be basically neutral, with summer generating real excess. (Assuming a suitable array for your consumption)
They use LiPo4 now
To me my electric usage (not including the car) is about 12-13 kwh per day. The tesla powerwall is the only one that comes close (last time I checked anyway), and I had a quote for about 10k (just the battery and installation, no panels) which is quite a cost.
Tesla powerwall is the rolls Royce of batteries. I would love one but there are cheaper options.
my pylon batteries are 2.4kwh each. I have 3 and iirc cost between 2200 and 2500 (for all 3 not each). 6 of them would therefore give you the storage you need . also, and not talking off grid now but more living on "off peak" power. if it were me I would buy the 3.5kwh versions however and have 3 or 4 of those.
in the 4 or 5 hrs of off peak energy you will not be running off batter either, you would be charging your home and using the grid so the batteries only need to last 19 or 20:hrs.
the biggest challenge of no solar generation and trying not to use on peak power would be the 3.5kw/h max output of the batteries. I don't know if you could install them differently to double that up (say 2 individual banks of 3), but for instance if I have the oven and hob on at the same time I can go way above that. from memory I have seen about 6.5kw/h being used in our home on a few occasions. usually when for what ever reason the washer and drier had to go on at the same time we were.prepping tea and my pc was on. (usually we don't do all that at once unless if off peak or our solar array is kicking out 2.5kwh+ but sometimes needs must)
My battery can output at 5 kW and 7 kW for 10 seconds.[Huawei 10 kWh LUNA2000]
nice! significantly more than mine. I was on a budget and at the time what I chose offered the best bang for my buck. things change all the time however (this was July 2021) and different use cases vary. with some fairly minor planning we can keep under the 3.5kw/h draw most of the time in winter and in summer we have more wiggle room with the solar.
You can daisy chain, I am getting 2 of these, 5.8kwh, can add upto 2 more, so potentially i can go to 23kwh (20/7 useable)
I will get max draw of 5kw due to inverter being limited at that, but going to be very rare I use more than that at any point in time
Sorry I realise they were other options. We have a gas hob, but electric oven. I don't think (again if I exclude the car) that we would pull more than 5 kW at once. The oven uses a lot for maybe 5 mins til it's upto to temp, but nor much other stuff comes close (we have a power shower so that's general the other big thing). I might look into the other options though as that's significantly cheaper. Even if you do top 5kw, I'd imagine it would be a short period, I.e. boiling kettle while oven element kicks in or something. Just don't tumble during the day and it's fine (assuming on go/intelligent).
Mains gas or Bottled?
If mains gas (and assuming you also have a gas boiler) you could switch to a boiler-fed shower instead to reduce your spike load and also swap some electrical energy to gas energy which is cheaper?
I've seen the power shower consume up to 10kW during the winter and that's not cranking it up. Usually about 6 - 6.5 on the dial. 7 if it's a really cold freezing winter. I've never seen it at 10 but I'd imagine it would hit 12 - 14kW.
Where as during this heatwave it was down to 2 - 2.5 on the dial.
Why in the UK do we always think of the now? It's not just the UK. Germany still using Russian gas. And being dependent it.
It boggles the mind.
Because it’s not popular. If a party says we wish to sacrifice something in the short term to benefit us in the long term. All the opposition have to do is say, “vote for us, no short term pain”. And people will do it. The parties know it’s irresponsible. But none of them care about the long term of this country, they care about getting into power and they will say and do whatever they believe makes them most likely to get it. And that is usually reacting to contemporary issues with short term solutions.
Doesn’t work like that at least mine doesn’t. I have 2 settings, one full power which is 12.5kw or 10.5kw I believe and one low power which 7.5kw. The dial just adjusts the flow in order to reach a lower or higher temperature depending on the number. It doesn’t alter the power draw at all.
Not surprised, chinese takeaway in town went from £1k a month on gas to £10k and decided to close down as a result.
Seems insane, can any takeaway joints really operate if they're spending so much on utilities?
I can only see them having to charge a lot more for food, at a time when people are likely going to be spending less on takeaways due to having to find money to pay their own utility bills.
Small businesses will need a lot more support.
