And what is the problem with that?
It doesn't work without it.
I take it you believe them when they say its by design.
And so what? Most if not all modern motherboards support it. It's been in the PCIe spec for years. This is not a problem.
dood come on the card has no AGP slot either! how embarrassingAnd so what? Most if not all modern motherboards support it. It's been in the PCIe spec for years. This is not a problem.
yea in "price to performance" not actual performance.hen he talks about how good it is of Intel not to over egg the performance, as if everyone else does, and then play the clip which Intel's marketing guy talks about how they are going to "kick ass"
Any reviews in regards to it being used with Linux?
Seems PCGH have been busy putting the A380 through more games:
In case anyone though Intel might be good at Creation Engine (Skyrim and Fallout), think again:![]()
Intel Arc A380 im Benchmark-Test mit 35 Spielen: Ist der Treiber nun reif für die großen Kaliber A750 und A770?
Teil 2 der Benchmarks: Was leistet die Intel Arc A380 im Vergleich mit einer AMD Radeon RX 6400? Das Low-Cost-Duell - inklusive Raytracing.www.pcgameshardware.de
The A380 performs well in some of the later RT benches, and for others the 6400's 4GB VRAM simply isn't enough.
Don't you just have to click on the left one: "Mit Werbung weiterlesen" that is continue with adverts.Unfortunately i can't access it.
Anyway I should have added the Google translate link too:
Welche Bildraten erreicht die Intel Arc A380? PCGH hat es mit einem frischen Treiber in 35 Spielen geprüft - inklusive Raytracing-Analyse.www-pcgameshardware-de.translate.goog
Other than in prebuilt PC's, I don't see a market for intel's GPU's.
The drivers being worse than AMD's is a technical achievement though, damn.
This road again.Are they on par with Nvidia then or better? Nvidia drivers have actually killed gpu`s in windows 10......https://www.pcgamer.com/geforce-drivers-36447-cause-catastrophic-errors/
This road again.
Yeah they have killed GPU's, but them driver problems are not persisting some 2 years later. Heck even longer in some cases.
When Open GL and DX11 are way past their golden age Nvidia were not then letting out performance updates either, they gave it us from the get go.
They are not, end of.ffs........ "AMD drivers bad" Nvidia have problems too.... "yeah but that was two years ago"
AMD driver problems were more than 2 years ago, they are just as solid as Nvidia now, stop with this crap.![]()
I am not worshipping, I am stating the truth, you won't encounter driver problems anywhere close to as consistent on Nvidia as you do with AMD.
But you know, to fit in, we must white lie things, them feels.
You are welcome to your opinion even if way off.You're talking poo.
