I’ll wait for independent reviews but looks like Intel are in for another kicking![]()
I think the 7700X and 7600X will get a kicking in MT by Alderlake.
For me the numbers just don't add up, i hope to be wrong.
Its like the VRam argument, isn't it?
You would never buy something that is 'just' enough on the day, no, not unless you were very budget constrained, you would want something that has some headroom, do i need to explain why? No, i don't, so this argument makes no ###### sense.
So the argument that you would only review something up to the point of performance on the day because that's all you need to know is Leninist tripe. Looking at you Steve Walton.
I mean buying a GPU every 2 years when the new gen arrives with a CPU every 3 years.Indeed it would be. But if you are buying a CPU every 3 yrs (I assume you mean 3 generations) and we are suggesting a new GPU every 2 generations then you don't need to worry about the performance difference of the CPU beyond two generations and thus the 720p is irrelevant.
With that it all depends what performance uplift you actually get at 1440p which is my point. If I get a 25% performance uplift in one CPU gen I would possibly consider that okay bang for buck. If it is only 5% then that fine and I will wait till the next gen. I wont know what that 1440p uplift is or not without that review and the 720p doesn't answer that.
It's probably why AMD avoided R23 this time around in their reveal.R23.
12600K: 17,660 $299
12700K: 22,812 $420
7600X: 13,175 $299
7700X: 18,258 $399
How....
5600X: 10,988
5800X: 15,228
10,988 + 9% IPC = 11,977 + 10% clocks? = 13,175
15,228 + 9% IPC = 16,599 + 10% clocks? = 18,258
For me it is, about $300 was just right. However, if the people buy them...Does anyone think $400 is too much for an 8 core CPU? Probably gonna cost ~£400 inc VAT.
I suppose AMD is hoping the multithreaded performance of the 7600X will be 'enough' for the low-mid end market.
R23.
12600K: 17,660 $299
12700K: 22,812 $420
7600X: 13,175 $299
7700X: 18,258 $399
How....
5600X: 10,988
5800X: 15,228
Jufes like to tune his systems and uses them for comparison vs out of box. His personal goal and his audience goal isn’t plug n play but optimal gaming configuration. Comparing his findings vs out of box is just weird…given he’s never catered to that goal.
https://kingfaris.co.uk/blog/10900k-vs-5950x/summary As demonstrated here by a buddy, tuned 10900k was a different beast esports or not.
As usual, amd is a great plug n play, out of the box platform and that’s fine for majority of the users as demonstrated on here.
He has no idea about tuning AMD GPUs or CPUs. He didn’t even have SAM enabled initially. I pointed out several things to him via YT comments, including to enable SAM. He said if I made one more comment on his channel I’d be banned. A few days later he makes a video telling his viewers to enable SAM. You can safely disregard anything he says regarding AMD. That said, I’m sure he’s more knowledgeable on the Intel/Nvidia front.His whole argument apart from complaining about SAM as far as I can tell is that he is saying when you manually tune timings on ddr4 and you get the latency to under 60ns then on AMD CPUs it causes deep dips in the 1% lows in games that don't occur when memory latency is over 60ns and for that reason he doesn't like amd CPUs and tells his viewers not to buy them because they don't "feel smooth"
Whether that's true or not who knows
Ill be happy with 5ghz on all cores or more in heavy workloads. Is that for 16 cores, 8 cores or both?It's probably why AMD avoided R23 this time around in their reveal.
It could be because the all core boost caps out around 5ghz in heavy workloads, zen 4 looks optimized for high SC which isn't a bad thing and there will probably be some room for curve optimizer tinkering for upping the MT.
That's interesting. I get anything between 16173 - 16611 on a i9 10900K. I thought the 5800X was higher?
Guessing the all core boost will be similar for all the CPUs now that AMD have up the power limit for the high core count parts.Ill be happy with 5ghz on all cores or more in heavy workloads. Is that for 16 cores, 8 cores or both?
AMD Ryzen 7950X3D, 7900X3D and 7800X3D tipped for CES 2023 launch - VideoCardz.com
AMD could launch updated Ryzen 7000 series already in January Greymon55 posted a cryptic message on Twitter, supposedly mentioning three upcoming Ryzen CPUs. At “Together We Advance” event AMD CEO Dr. Lisa Su announced four processors of new Ryzen 7000 series. The company also confirmed it is...videocardz.com
so long raptor lake if this is true, that cache size is nuts!
how a 15 to 20% performance gain vs the 5950X, all the ones that lost the most to the 5950X, conveniently.
Now, the thing is the 10900K can boost to 5.1Ghz on 4 cores simultaneously, to get those sort of performance boosts it
We had the same argument a couple of months ago, I was telling you that the 10900k most of the time was faster than the 5950x in gaming and you were saying otherwise. I have personal experience with the cpu, and im telling you that it can easily support 4400-4600 c15/c16 ram. Im not even talking about cache and cores oc, just by tuned ram it flies past zen 3 in most games. You cna literally get down to 36ns of latency with a 10900k.Care to add any actual data to that? Data has no feelings.
Where did you get these numbers from? I Think the 7600x will be around 15k in CBR23, at least that's what one of the leaks suggested. Keep in mind though, the 13600k will be 60% faster at 24.5kR23.
12600K: 17,660 $299
12700K: 22,812 $420
7600X: 13,175 $299
7700X: 18,258 $399
How....
5600X: 10,988
5800X: 15,228
My 12600kWhere did you get these numbers from? I Think the 7600x will be around 15k in CBR23, at least that's what one of the leaks suggested. Keep in mind though, the 13600k will be 60% faster at 24.5k
We talking about stock settings thoughMy 12600k
Hovering around 20k on a 12600k requires minimal effort.
Do you think RPL will retain the ability for bclk overclocking non K as a $200 13400F would offer insane performance per dollar on something like a B660 PG riptide?.My 12600k
