- 18 Mar 2012
- Eastbourne
Some cutting, some welding, some painting and we now have a hydraulic clutch and a electronic pedal.
. They also jacked it up in the sill too which has dented it.Ha. Maybe doing decorating and that was for collection. It’s sat for years unused so better to go to a good homeSorry to hear, surely if you moved the sofa you could park the eV there rather than having to get rid of the s2k?
That's most likely going to have to go to a proper spray booth its really hard to do roof resprays! Not going to be cheap either!!Found a paint issue...
Paint has started bubbling on the roof. What's the chances this can be fixed without needing a full respray? Guessing not an easy job?
Sorry, on my phone and accidentally quoted above comment!
That screen will have to come out as that's the source of the corrosion.Found a paint issue...
Yep, ordered plenty of times. Usually use the safe order option as it's saved my bacon a couple of times.Not done today per say but need to sort the front pads out on my 120d e82 ,
Anyone ordered from autodoc website before? Never run in to this place before
