I know a few people with agas/everhots @the shadow and they are far from 'rich' just people in decent jobs. Seems on this forum and in society in general anybody with something nice is considered 'rich' and I can only equate it to petty jealousy.
I'm not sure how viable that is though. There has only been one occasion this month so far (one hour on the 9th Sept) where our overall consumption exceeded 1kWh in an hour, thats with running a dishwasher, washing machine or oven at peak periods.In the test (the Octopus one) they took your average or something (last week iirc) and then based it on that.
That would be tricky at a larger level so maybe its actually a time when a simple cap applied to every bill would make more sense.
You need a smart meter of course.
Edit what I mean is, apply the credit to everyone on a smart meter using less than say 1kw per hour during the peak period. Measured each 30 minute period.
So if you less than 3kwh between 4pm-7pm you get a credit. Otherwise its a bit open to abuse.
I suspect you would need to really have anyone who wanted to do this on a fully variable tariff once it caught on.
The scheme doesnt exist yet right? They dont know until they launch it.I was just reading the same article myself. Even 52p/kWh would seem to be very promising to me. I wonder how they measure how much you 'save' though? How do you measure what someone doesn't use? Seems more sensible to just have tariffs which cost less at different times of day, rather than trying to refund people for what they haven't used.
Jest@the shadow...... i think that is actually unfair on wealthy people.... in the grand scheme of things our family is very fortunate.. and whilst i have said before i am far from perfect but even so i like to think i do what i can and defintely like to make every kwh work as much as it can for me.
mind you my mrs does tell me i am tight!(I like to think of it more as enjoying getting the most value out of stuff that i can )
Ok the way you described it seems dumb, so someone moving onto it who already has considerable off peak usage from day one wouldnt be deemed as saving energy as that would be their baseline?Yeah thats my point, its open to abuse for sure depending how its structured. Hell worst case it could end up being like that scheme in NI where people were using all they could to get the rebate.
IMO we have to move to 30 min variable pricing for everyone. Those most able and willing will move consumption which should along with V2H and V2G and home storage should really help to lower the peak demand.
People that will struggle to move usage from the current peaks should see lower bills as should everyone else. How can everyone win? Well the last generation units added to the grid are the most expensive, we eliminate them the average for every unit goes down.
I'm really interested in how they calculated it. Surely you could sign up to tariff, install an EV / battery and then charge it overnight for a massive off-peak spike. Then since the rest of your daily use is "below average" they'd pay you £1-£2 per unit used...
They just need to do TOU pricing instead, dont see whats so complicated about it.
IMO thats probably the most perfect example of how cheap energy has formed peoples usage
Wow that gas usage is mentally low. 1kWh of gas. I mean a gas hob used is 0.9kWh alone so that for 20mins is 0.3kWh. A 5min shower is around 1.22kWh (4min shower using about 30ltr water), so those two alone is going to use 1.52kWh in a day. I really can't see it unless you of course as a family of 4 all shower only once evert 2 days all together for that 5mins?It varies day to day but August was.
208.72 kWh Electric
34.47 kWh Gas (3.02m3)
Decent job, no dependants, does make you rich relatively its personal perspective. Vice versa nice job with family to support is not often making you richthey are far from 'rich' just people in decent jobs.
We don't use any heating here at all and haven't had heating on since last October and yeah 1 5min shower a day is enough to use minimum of 30kWh of gas a month so really boggles mind.Our energy use for August was only 199 kwh for electricity and 22.4kwh for gas, a grand total of £52.94 for the whole month. That's a soon to end fixed deal and we only use gas for hot water and heating which has been off for several months. It has been easy to cut the usage for the pair of us.
Wow that electric is low do you have solar?Our energy use for August was only 199 kwh for electricity and 22.4kwh for gas, a grand total of £52.94 for the whole month. That's a soon to end fixed deal and we only use gas for hot water and heating which has been off for several months. It has been easy to cut the usage for the pair of us.
If your meter is metric then multiply by 11.1868. It’s roughly 35 if it is imperial. Usually it mentions on the bill the readings and then the amount of gas used.What is the calculation to work out gas usage from meter readings,
The meter has gone up two units in a week
Not sure why you putting it in caps, I didnt know about the test hence the question.I was describing what they did as the test. You know they did a test right?
They literally took peoples usage and tried to incentivise them to use less. They were testing, when incentivised did people use less or not bother.
Lets do that again, USE LESS.
So you need to do it at an individuals level on that basis to check that they USED LESS.
But as I said it really only makes sense to go hand in hand with variable pricing. Since we need to spread the grid usage as flat as possible and likely simple time based are going to cause their own peaks eventually. Eg once a lot of the population have EVs on a go type tariff.
I don't know tbh. My Octopus account gives me the kWh figures for the gas so can see day, week, month and year. But my 250kWh is about 16 units all in so about 4 units a week then approx.What is the calculation to work out gas usage from meter readings,
