Hi all,
After 12 - 18 months out of gaming, I'm finding myself drawn back and wanting to replace my 5700XT.
I've seen a 6900XT at a decent price (comparatively) and was about to pull the trigger when I thought I'd check some YouTube reviews only to find several 'influencers' losing their minds, specifically when it comes to Warzone (which was the last game I played extensively). Something about "micro-stutter" making the game unplayable.
Is it really that bad? I'll probably jump back into Warzone for a bit, maybe some Hunt Showdown and then the next COD/Warzone 2 but I don't want to shell out cash if there's a known issue with this card and Warzone. Can anyone put my mind at rest please?
Yep issue under investigation. Does not affect all users. It's limited to one map (Caldera) and generally at low settings and resolution only 1080P/1440P.War zone debug thread continues, from memory it was one level and both AMD and the developer are working on it. In other the news it’s a fab card.
If you use max settings or 2160P, you may never experience it.
Hopefully it will be fixed in a game update. All other maps work flawlessly, and RDNA2 is much faster (25-50%+) than Ampere at all settings/resolution/maps.
