NVIDIA 4000 Series
The memory bandwidth difference between a 3090Ti and a 12GB 4080 is about half? That will surely show itself at some point, perhaps at higher resolutions.
The biggest hit to the gonads though.. 192-bit 12GB at 900 smackeroonies.
The GTX 660 was a 192-bit card and they did the same trick back then... Moved the whole naming scheme around and labelled lower end GPU's as higher tier.
780Ti was the 680.
A 3090Ti at the current FE price might not be such a bad deal. Sure it lacks 3.0 but I bet plenty of 12GB 4080’s will be around the same price, and in some cases have worse performance and half the vram. Less power consumption admittedly.
Indeed , a 3090ti with dlss 2.xx will be absolutely fine for the next 2 years or more , same as a 3090 or 3080.. dlss 2.0 really has given them a new lease of life . The only reason you realistically need to upgrade to a 40 series if if you want to push really high fps at 4k native which is where these new cards should shine although I've absolutely loved using the 3090 for the last 2 years and with dlss in the games I play will hit 4k 120fps most of the time . Still does very good fps without dlss but a 4090 will do it with ease at native and have room to spare . :)
People saying the 4080 has less tensor cores But not far above Nvidia slides showing they have 700+ which is over double?
Is there no way for them to increase the number of RT cores per SM? seems like RT is really held back by how few RT cores they have.
Raytracing is more limited by data access and caching since rays diverge a lot more that a grid of rasterized pixels. With hardware accelerated traversal and intersection of the scene by rays the bottleneck becomes accessing the required data.
I’m waiting to see what RDNA3 offers.:)
Proceeds to buy a 3080 TI. :D
What‘s wrong with that, is there something stopping me buying a RDNA 3 card if they deliver? :D
I am concerned enough that AMD will joining Nvidia with the silly prices that I went this route. If AMD deliver and don’t take the biscuit with price I will upgrade, if not I am good until 2024. Win win no? ;)
tbf the 3080ti will likely go up in price after the 4080 12gb reviews.
My 3070 is in some sort of weirdo limbo now, it was upper mid range, now mid range.... thanks Nvidia you something beginning with W and involves shaking your hand up and down like you are stabbing someone rapidly.
it says on the overclockers buying page that some of the 4090s are £1679 for example the:
KFA2 GeForce RTX 4090 SG 1-Click OC 24GB GDDR6X​
and others. I'm presuming that's just there but not the final price??
The Zotac Trinity is 1,898 quid......
Strix, 1,950.
TUF OC 1,860
GAMING TRIO X MSI 1,799
GAMEROCK OC 1,799
All the good cards will cost a minimum of 1,750.
What usually happens is you have a bunch of cards showing msrp up till the launch then the website crashes and once it reloads you find they have all gone up a few hundred quid.
The problem with switching to AMD is not so much the performance as RDNA2 has shown but its the extra's that come with Nvidia cards that makes AMD cards a hard sell. For one Nvenc is a pull for streamers because they don't need a capture card to get decent streaming performance and of course AMD does not have CUDA support
