- 28 Sep 2014
- Scotland
Deleted
Just ribbing ya dude, they're slowly starting to come out and you should have a few options at launch with a little luck. Not sure who does PSU's atm @Gibbo but maybe when you start to get stock then they could throw up a thread in here too so people can order?Will nab one of those
What's new is the amount of current being pulled through such small pins.
I dont think that not when Sony can make a profit on the disc PS5 at £450 which has a larger die than the AD104 16gb vram, larger heatsync and case with a built in psu, controller and 800gb gen 4 nvme thrown in, ok its TSMC 7 vs 5nm but then Sony has to buy from a middleman AMD and im sure AMD wont be selling at a loss.You'd think but from what i was reading last night it seems it maybe the other way around, or at least Nvidia may have much smaller margins on the smaller die's.
It wouldn't have been finalised until quite recently but they definitely designed it 2-3 years ago
I honestly think 4080 priced are subsidising 4090s, and that gamers as a whole are subsidising R&D for enterprise and professional.
On this thread :-Rule 1... what people decide to buy is their business not yours and it's their money not yours.. (also remember people buying at the top end (enterprise too) are subsidising the cards down the stack and always has been this way with worse binned chips at a more realistic price for the masses, don't shoot the people at the top end as they help to make the cards at your range better priced, fact before anyone argues about this.)
That doesn't leave much wiggle room for pins when they start to, well, wiggle.Shouldn't be an issue as each crimped terminal inside the 12VHPWR is rated at 9.2 amp and 6 of the pins are the +12volt so you have 9.2 amps x 6 for 55.2amps then x 12 volts for 662.4 watts.
I wouldn't be worried about it anymore than I would bending an 8pin PCIe too much and causing it to short out or overheat.
Edit:
Just to add, the key thing on this slide from the GN video is "Cables with low cycles and without bend condition have not failed" so, I'll be attempting to keep bend conditions to a minimum and mating cycles as low as possible to be safe
Benders that have a lot of unsafe mating cycles are going to run into issues!
I guess if they start to move about like an old 4pin molex it’s time for a new cable!That doesn't leave much wiggle room for pins when they start to, well, wiggle.
They should have just gone with a kettle lead.I guess if they start to move about like an old 4pin molex it’s time for a new cable!
The PS5 uses a customer Zen 2 CPU and RDNA 2 so it's 7nm, not 4/5nm.I dont think that not when Sony can make a profit on the disc PS5 at £450 which has a larger die than the AD104 16gb vram, larger heatsync and case with a built in psu, controller and 800gb gen 4 nvme thrown in, ok its TSMC 7 vs 5nm but then Sony has to buy from a middleman AMD and im sure AMD wont be selling at a loss.
Well put my money where my mouth is, just picked up a series x and 3 extra controllers for under 700 euros, not cheap but should get value for money, still use my 360 periodicallyHonestly Xbox and a few extra controllers is the way to go for me, already pay for gamepass and will still have the PC to run any exclusive titles albeit not optimally, sad![]()
PS2/3 360 and OG XBOX here.Well put my money where my mouth is, just picked up a series x and 3 extra controllers for under 700 euros, not cheap but should get value for money, still use my 360 periodically![]()
cheapest ones Ive seen are Thermaltake for £260 due october. MSI have brought some out too but not available yetWhen are the 3.0 PSU's due?
