yeah 13900k reported rage mode can eat close to 350w, RIP cooling that sucker226 watts? 12900K pulls more than that.
I mean the CB score is. With all the cores loaded on a demanding MT task, the performance of the 13900K and 7950X is going to be close but the 13900K is going to be using a lot more power.226 watts? 12900K pulls more than that.
I wonder if Zen 4 will support speeds upto 8000 MT/s? and will it be worth it?
Close to a power unlimited 13900K by the look of things.
unlimited power 13900k hits 345w in R23 according to the leaks. 35693 points using 254w
AMD Ryzen 9 7950X overclocked to 6.7 GHz scores 50K in Cinebench R23 - VideoCardz.com
Overclockers take AMD Ryzen 9 7950X to new heights Extreme overclocker Sampson, who is part of the AMD overclocking team, published a new world record achieved with AMD Ryzen 9 7950X CPU. AMD Ryzen 9 7950X with LN2 cooling, Source: HWBOT/Sampson Just three days ago, the same overclocker claimed...videocardz.com
7950x overclocked on ln2 6.45ghz and the chip pulled 271w and scored 48k in r23![]()
Intel Core i9 13900K Breaks Record in Cinebench - AMD is in trouble!
Hate to break it to you guys, you are comparing oced tuned numbers with stock.
But unless you tune both you arent putting them in similar conditions. The numbers of zen4 are from xoc with exotic cooling.stock zen 4 is impressive (air or aio), as with intel were just discussing what amd can do when put under similar conditions as intel, truly impressive from amd
If thats with 170w consumption. I think its not, i predicted it will hit less than 35k @ 170w. At 220+ sure, it can do 39k39,000 Stock, right where i said it would be months ago...
Sure, as does the above 7600x against the 13600k. Or the 7700x. Or even a hypothetical 7800x. You need to go up to the R9 7900x to compete with the i5,lolthe above stock 7950x run vs the stock 13900k run paints a pretty clear picture tbh
6 core 12 thread vs 14 core 20 thread not really fair is itSure, as does the above 7600x against the 13600k
Then ask amd to increase core count or decrease prices, lol6 core 12 thread vs 14 core 20 thread not really fair is it
