- 24 Aug 2005
- Uranus
Oh no we won't.I feel like 4k 3090 users might jump on the 4090 upgrade path however 1440p and below really should skip this gen.
Okay and maybe VR users tooOh no we won't.![]()
That was because we couldn't buy one at the low msrp/rrp prices... now it's a case of we don't want to buy them due to the high prices![]()
Just dropped some cash on a "cheap" 3090 TI Suprim and flogged a 3080 TUF OC. Stupid MaybeTime will tell.
dittoOh no we won't.![]()
Wow, that's a stealditto
Blimey I bought a new 3090 last week for £899 and the place I bought it from had loads of lines now they have only 2 left and the card I bought is now £1299!
OCUK's have gone up £159.
Even as someone who has put ~500hrs into it (and will likely do at least half that again by '24), I still can't count it. Truth is the biggest difference maker are the RT reflections, the other options are nice too but it's easy to ignore them during gameplay. I don't think the added options by overdrive are so important as to dictate an upgrade. In fact in some screenshots (see: https://imgsli.com/MTI3NzAz) I think it might be a problem because similarly to Dying Light 2 (see: https://i.redd.it/tkb8ai2xnof81.png) it tends to over-darken some areas which for me is a big no-no and why I turned RTGI off in DL2. More "accurate" in theory, but awful in practice. Cyberpunk also has an issue with its eye adaptation tech which compounds this problem (and has been made worse post v1.3 when they re-did HDR, though this applies to SDR as well). Ultimately I'd like the option of having the performance of just turning it on if I feel like it but I'm not as eager to get it as I was to get RT Reflections in the first place (SSR begone!).We have cyberpunk again this time around! Just with overdrive dlss 3 modes![]()
How many people re-play it? It's an old 3-5hr puzzle game, I don't think an upgrade has so much value for it.Portal RTX in 4k?
£1500+ 4080 16GB's incoming...
They treat it as some kind of poker game tbh, pushing the clocks as far as they can right to the last minute and only revealing them usually.Anyone know why most of the AIB partners haven't revealed their respective clock speeds yet? Is there some sort of NDA/emargo that prevents them showing the clock speed if it's +/- 100MHz compared to the FE?
Think that’s it but Gibbo gave some interesting nuggets of information that the difference between OC and non OC versions is going to be large. That the OC versions would be 200mhz higher but he couldn’t confirm at this point.Anyone know why most of the AIB partners haven't revealed their respective clock speeds yet? Is there some sort of NDA/emargo that prevents them showing the clock speed if it's +/- 100MHz compared to the FE?
And 5 times worse pictureHas anyone watched the Digital Foundry video, the 4090 using DLSS 3 is on another performance level to 3000 series. Frame Generation gives up to 5 times the performance.
