It's never in stockRTX 3080 available direct from nvidia.. honestly the prices of the 40 series I'd just grab the 3080 still enjoy a phenomenal performer and sit this gen out...
Yeah, I was wrong, plain and simple. God knows why I've believed this all this time. D'oh!I hopefully your pc building knowledge is better than your PSU knowledge!The efficiency rating doesn't mean you only get that percentage of the PSU's rated power output. It's actually how many watts are drawn from the wall socket compared to what is actually being supplied to your PC. A more efficient PSU will have a smaller delta between wattage drawn from the wall and being supplied to your PC so it's cheaper to run and should run cooler.
Though I do agree I wouldn't use a 750w psu with a gpu that can pull 450w or more.
Edit: Doh! I go make a drink mid post and you make an edit!![]()
Its literally available nowIt's never in stock
We all learn new things every dayYeah, I was wrong, plain and simple. God knows why I've believed this all this time. D'oh!
RTX4090 has shown up in Geekbench cuda benchmark. Scored 75% higher than RTX3090. For reference, the 3090 scores 45% higher than RTX2080ti in this test.
The 3090 is 40-50% faster than the 2080ti gaming, so perhaps the 75% is an indication of where average rasterisation performance will land
It may be because Thor 2 1200W is not available, while 2 1000W is - they just want people to buy their available PSUThe 4090 Strix OC recommended PSU is the Thor 1200 P2 (on the launch materials) but the tech. spec page for the 4090 Strix OC says 1000w PSU.
the TI not the 3080 and there have been 3080ti for £800 recently which is way cheaper than the 3080ti FEIts literally available now![]()
Maybe its sold out now, but it was available for a decent few hours for 649 quidthe TI not the 3080 and there have been 3080ti for £800 recently which is way cheaper than the 3080ti FE
That’s nice man, I don’t know if I can wait until November though.![]()
Gigabyte unveils GeForce RTX 4090 Aorus Waterforce GPU with 360mm AIO cooler - VideoCardz.com
AORUS Waterforce with 360mm radiator Another liquid cooled RTX 40 GPU. Gigabyte’s latest AORUS model for NVIDIA Ada architecture is indeed smaller than the humongous RTX 4090 Master, but only because the cooler has a massive external 360mm radiator that still somehow has to be fit into the...videocardz.com
Just seen that Gigabyte are going to release a 360 AIO version of the 4090. Looks like a step up from the 240 MSI Suprim AIO. No idea on availability though but I think Gibbo said before that AIO versions would be available in November.
Edit - Just seen a product listing for it on Overclockers page for £2299
I would steer clear of this card. This is the same design as their 3090ti. Memory temps are worse than any 3090ti AIB(even air cooled), GPU temps are not convincing either. Waste of money over good AIB:![]()
It has a 4 year warranty which isn’t bad for reselling when you get to the 5xxx launch!people with AIO GPU don't worry about what happens when the pump dies out of warranty?
Does anyone know much about the Corsair cables that they are doing for their PSU? Every time I go to their page it says find retailers and OcUK is listed but I can’t see them selling it.
I’ll be honest I’m torn between getting the thermal take 1650w or just getting the 1600i.
I mean what if next gen they increase the power again, I assume that any non atx 3 psu might then struggle?
I am assuming Corsair did the same thing as Asus, see my cable for Thor 1000W:Does anyone know much about the Corsair cables that they are doing for their PSU? Every time I go to their page it says find retailers and OcUK is listed but I can’t see them selling it.
Afterburner's power slider is limited by what's in the BIOS.You can switch powerlimit in afterburner
Jensen during presentation literally said you can increase power limit to 600W for overclocking.Afterburner's power slider is limited by what's in the BIOS.
That would be the largest Afterburner power adjustment I have ever seen by a crazy margin.
+35% on the power slider?
