I think you can buy it direct for the same price.
Balls, i didn't see that code.
Boom! Loving it
I wish my set up was that clean.... unfortunately I'm in a barrack block and have no choice on furnishings so.... everything's super cramped
What settings have you owners of the AW38 made?
I haven’t got a device to calibrate with so have used the online one I’ve used before but to my surprise, this monitor seems bang on with contract and gamma.
I’ve dropped blue down a few notches on the RGB as it’s seems most if not all need it to tune the white balance.
Thanks - yes I figured that'd be a good shot so have left it for most of the afternoon. Will check this eveningTry removing all power from it for a few hours (that means unplugging it, not just turning it off) -- the image has to be stored in a buffer or something surely, hopefully running out of juice will clear it... maybe xD
Bizarrely I have just taken delivery of a brand new Lenovo laptop today and the screen has just done exactly the same!!!!!!!!!!!!Hmm - weird thing happened today with my AW3821DW. My Mac crashed (logs suggesting USBC related issue) and after reboot the screen from before the crash is retained as a ghosted image.
This persists with different cables, different computer, and even when the energy saver screen is showing:
Anyone had this before? I've opened a support ticket with Dell but would assume I need to ship it out...long.
Have you tried updating the firmware?Left it unplugged overnight in the end, unfortunately it is still there...if a little faded.
Dell support ticket is in progress, so let's see what they say.
In the end, I sent the old one back. During setup, I had both side by side and the old monitor actually went "pop" and didn't back on again. I can only assume the symptoms i saw were signs it was on the way out.So when I got home from work yesterday, I checked it again and sure enough the image retention had gone. However, Dell have already processed a replacement monitor which should be arriving today.
I'll compare the two and send the worst one back!
This happened to mine on Saturday. Logged a ticket and the replacement turned up today. It has a newer firmware revision (03, old one 01). I left the old one unplugged overnight and it fixed it, but it seems widespread. I've kept the new one.Anyone had this before? I've opened a support ticket with Dell but would assume I need to ship it out...long.
Hmm, strange timing - I got back from work yesterday and had plugged to do my final calls for the day. I noticed signs of image retention again :/ Will do some more testing tomorrowThis happened to mine on Saturday. Logged a ticket and the replacement turned up today. It has a newer firmware revision (03, old one 01). I left the old one unplugged overnight and it fixed it, but it seems widespread. I've kept the new one.
That's frustrating. At least Dell support is decent.Hmm, strange timing - I got back from work yesterday and had plugged to do my final calls for the day. I noticed signs of image retention again :/ Will do some more testing tomorrow
