Then buy the DeWalt if you have batteries for it. Or wait until Black Friday when the Ryobi will be £85.That top line Ryobi drill is more expensive than dewalts top line dcd996 as a bare tool.
I think you need to stop thinking those cheaper dewalts are any better than the erbauers etc. They really aren't until you step up to the more expensive tools.
Agree.
I’ve got loads of hilti kit, the problem with them is they’re heavy duty stuff and yeh they are better but not enough to justify the cost also they don’t do enough tools, they still don’t do a wet dry hoover or a multi tool, chop saw etc.
So I went for the milwaukee m12 - their stuff is superb and pretty much have enough oomf to do everything. If I was going down the route of getting things like leaf blowers, grass cutter, hedge trimmers etc I’d be looking at their m18 range. It’s massive.
I'm sure a little bit that if I wasn't tied into Bosch, then Milwaukee would have my money.
Those asking what is best online is one of those questions that will never get an answer you are expecting, as everyone will have their favourites and will swear by them.
Do a few independent reviews online and also check what trade (not sponsored trade) use day in-day out and take into account that some premium names will use **** parts on their lower priced products.
There might not be a best product overall, but considering pricing there will be an optimum product at any one time.
Like for example if erbauer and DeWalt were similar price then choose DeWalt. Or for example is it better to get a bundle kit with impact driver for £200 or a better drill individually for £130.
And it's incredibly difficult to tell if the DCD778 bundled with the kits is better or worse than for example the dcd796. Or is the Erbauer matching those or not?
Plus the pricing is all over the place. Screwfix have 3 or 4 versions of the bundle kit all at £199 with different battery sizes and one is a refurb unit. How can the refurb unit be the same price as the new unit.
Yep Bosch Blue for the win.. Never had one fail. Even had the 36v SDS fall off a roof... Was more worried about by newly fitted Indian stone than the drill.... Knew the drill would be okI swear by Bosch Professional tools and if you know where to look they can be had at a decent price.
Yep Bosch Blue for the win.. Never had one fail. Even had the 36v SDS fall off a roof... Was more worried about by newly fitted Indian stone than the drill.... Knew the drill would be ok![]()
B&Q (as far as I’m aware) are running out Ryobi and don‘t have any of the newer HO tools, which I think are only available on the Ryobi website. I’m sure Erbauer are great and so long as you can guarantee they’ll keep making batteries for them I’m sure you’ll be really pleased with them. The “safety” in a big brand is they don’t change the batteries much so you can continue to get compatible tools and batteries going forward. That’s why I don’t buy Parkside, Worx, Erbauer etc.Just had a browse round b&q. The Erbaur range has got a very DeWalt like feel to it, almost the same dimensions and with the rubbery grippy feel. The Ryobi range is more plasticky in comparison and slightly less compact.
It’s VERY unlikely that a screwdriver will undo screws that you cannot undo by hand. They just don’t have the torque.I'm getting pretty desperate for a drill now chaps after needing to do some work in my kitchen tonight and not being able to get some screws out by hand as they've been driven in hard.
Which is the best deal out of these:
DeWalt DCD709D2T-GB 18V XR Brushless Compact Combi Drill
Powerful yet compact, the DeWalt DCD709D2T combi drill guarantees impressive performance in the tightest of spaces. At just 175mm in length and weighing only 1.6kg with the battery attached, this drill gets the job done when there's not much room to manoeuvre.Powered by a two-speed brushless...www.toolstation.com
Error 410 | Screwfix
Thousands of products at low trade prices | FREE next day delivery available | 30 day money back guarantee on all orders.www.screwfix.com
DeWALT DCD796D2 Combi Drill 2-18v-2Ah Li-ion Batteries Brushless
DCD796D2 Combi Drill 2 x 18v x 2Ah Lithium Batteries Brushless MotorDeWALT Power Toolswww.powertoolsuk.co.uk
Or a bundle with impact driver eg:
DeWalt DCK2060M2T-SFGB 18V 2 x 4.0Ah Li-Ion XR Brushless Cordless Twin Pack - Screwfix
Order online at Screwfix.com. Versatile twin pack comprised of a brushless combi drill and brushless impact driver. Both tools feature all-metal gearboxes and bright white LED work lights. The combi drill features 15-position adjustable torque settings with screwdriving, drill driving and hammer...www.screwfix.com
I just need to know which one of those is best value for money spec for price.
