I mean best thing we can hope for is these companies price themselves into bankruptcyThe problem its ominous when a 104 series die which is barely 300MM2 is going for over £900. It was bad enough when the 104 series dies became a 80 series dGPU,but now they are selling for 80TI/90 series type money. The RTX4080 12GB has under half the CUDA cores of the RTX4090. An RTX4070 is most likely going to be a 10GB card with a £700+ price.
The next 60 series dGPU will have a die probably close to 200MM2,probably only 8GB of VRAM,and be well over £500 which is insanity. If AMD does not have something that is better value for money under £1000,I really don't know how these prices will be maintained with Europe entering a severe recession(due to lack of energy) and a global recession because of rising commodity prices,and higher and higher interest rates.
I mean best thing we can hope for is these companies price themselves into bankruptcy![]()
Nobody can say for certain till tomorrow's reviewsDoes anyone know whether the top AIB cards are going to support pushing the power limit over 600W or is that a hard limit?
No one cares about price per performance !No it isn't. Just look at this chart:
Now consider they are pushing up the price of the 104 series die to $900. Now,look at the specifications - this is another Turing level stealth price increase.
Nvidia has lots of Ampere based dGPUs and does not want to discount any of them. If people keep buying these new dGPUs at the overinflated pricing it will stick....during a global recession.
Now think where the "RTX4060" will lie - it will be literally a tiny 40/50 series die at nonsensical pricing.
And that's not the best part. The most interesting part is talking about power efficiency peaking at 60%. For 33%+ less power use (that's 300W TDP!) one would lose only 5% (sic!) performance! That suggest they pushed this card into hardcore OC region for some unknown reason - do they know something we do not? It could've been half the size of the cooler, cheaper, etc. if they didn't push it to the very limit.Der8auer showing power draw less than 3090ti in games.
4080s will not sell. 3080+ is a much better value proposition, theres so many around and 4080s will look terrible in comparison. Everyone who could have theoretically afforded it will go for the 4090 instead. The number of buyers at this price range without mining is a relatively small pool. You will see both 4080s dive in price in the space of months. Buying one is, in effect, equivalent to chucking money away.The problem its ominous when a 104 series die which is barely 300MM2 is going for over £900. It was bad enough when the 104 series dies became a 80 series dGPU,but now they are selling for 80TI/90 series type money. The RTX4080 12GB has under half the CUDA cores of the RTX4090. An RTX4070 is most likely going to be a 10GB card with a £700+ price.
The next 60 series dGPU will have a die probably close to 200MM2,probably only 8GB of VRAM,and be well over £500 which is insanity. There is going to be a severe performance stagnation(outside RT benchmarks) I suspect. If AMD does not have something that is better value for money under £1000,I really don't know how these prices will be maintained with Europe entering a severe recession(due to lack of energy) and a global recession because of rising commodity prices,and higher and higher interest rates.
It's not 70-80%, he said it clearly, it's 50-60%. With 60% power target (about 300W TDP) one loses only about 5% of overall performance.DerBauer does an interesting graph on power target to FPS. The most efficient spot seems around 70-80% power target.
Or electric costs! or any other doom and gloomNo one cares about price per performance !
Its fine for the 850 FE a few reviewers are using that with no issuesI see there's some reviews out of the 4090FE, any yet confirming power supply requirements such as will 850W be enough?
That's one review right?This is 45% faster, that's less than the difference between the 2080Ti and 3090, does that live up to the hype?
1/.69 (3090 to 4090) is basically the same as .61/.42. Same generational jump of 45% seemingly.This is 45% faster, that's less than the difference between the 2080Ti and 3090, does that live up to the hype?
Like the 7000 launches, I doubt these are going to fly off the shelves. This is a niche product for 4K gamers on PC, and for people who need one for work. Looked at the AMD 7000 series CPU's on OCUK store yesterday, all appeared to be in stock...5000 series flew off the shelves, for some months. I assume AMD will also make the mistake of pricing their new GPUs into the stratosphere. AMD and NVIDIA are both in for a shock, no mining to sell off to on the side this time.I'm scouring fleabay for pre 4090 launch sale adverts and im surprised i don't see any at all. Remember last year a day before 3080's launched, adverts were popping up all over for around £1k?
And why would one do that? Debauer shown efficiency graphs and there is almost a flat line above 350W up to 450W. This card is already pushed way too hard by the looks of it, with power use, which give only about 5% performance uplift above 300W-330W. Pushing it to 600W would likely achieve absolutely nothing aside just increasing your electricity bill.Nobody can say for certain till tomorrow's reviews
