I'm not sure that CPU limitation matters that much - There is always a limitation between CPU and GPU, this seems to be the first time that CPU limitation is potentially a bigger issue than before.
Unlike before, the limitation seems to be on the cheaper item to replace, which is surely the best way round?
Not sure about cheaper,. You seen the price of th new motherboards? New mobo and cpu likely to cost almost as much as the 4090 did./
