- 21 Jul 2005
- Officially least sunny location -Ronskistats
Anyways will see the real uplifts later today and if all the hype was worth it for MSFS users.
And all the 30 series cards that were in stock yesterday are back in stock again:
3080ti
3090ti
3060ti
3070ti
So im guessing it was likely a glitch on the site earlier considering it went offline for a bit as well.
Go back a page, Ravenxxx post 13,233Still blocking anyone who has purchased one of the cards before?
Do you have the Reddit channel? I’m toying between 4090 and 3090ti and play MsFS
EditerTech Alpha Insider
2d
I didn’t do thorough recorded benchmarks or anything, but I did do some baseline performance comparisons to see the performance difference between the RTX 3080 10GB and the RTX 4090 24GB on my existing system, with a 10900K, 32GB RAM.
No regrets on the upgrade, but in my limited testing of a couple of hours of playing around with the card, my initial impressions are:
- In heavily CPU-bound situations (settings on Ultra, poor performance areas like NYC/London/Seattle), the sim is completely CPU bound even under DX12, and my frame rates were basically identical (within 1-2 fps) without the DLSS Frame Generation turned on. Once I turned that on, FPS mostly doubled. From 40ish around NYC to about 75 on average in the same area/plane/weather. (5,120x1,440 monitor, so essentially similar rendering demands as a 4K display.)
- There’s a been a lot of talk about visual glitches with frame generation turned on. I have never seen/noticed such a glitch. I could probably find some if I video-captured a flight and frame-by-framed, but I’m not seeing/noticing them in actual flying.
- In VR, though, I did see a pretty big increase in frame rate over the 3080, even without DLSS 3.0/Frame Generation being available. Because I’m less CPU-bound there (I had the LOD turned down to 100 to maintain a good frame rate on the 3080), I went from around 45 fps to about 70-72 on a Reverb G2, which is dramatically faster. This is with motion reprojection off. (MR artifacts bug me.) Enabling DLSS quality gave me about the same frame rate as 80% resolution scaling but a little sharper image.
I have a 13900K on order, so it’ll be interesting to see how much that combo increases performance.
- In games, which are usually GPU-limited, the 4090 is a beast. In MSFS, which is easy to CPU-limit, it’s still a beast, but only because of the frame doubling. If you’re CPU-limited, you may not see much difference over a 3080 unless you run DX12 with frame generation enabled.
- Given that all the real increase is coming from the frame doubling, rather than rushing to get a 4090, watch to see what kinds of frame rates people get in MSFS with 4080s or even 4070-level cards. If you’re seeing your base performance CPU-limited, those cards will also offer DLSS Frame Generation, and you may get identical performance at a lower price.
- The moral of the story is you’re gonna need both a killer CPU and a 40-series video card to get the most out of MSFS.
Really interesting results. I’ve no interest in VR and I have a similar 32:9 monitor setup. Im not too fussed by DLSS as I like my quality non blurry cockpit! Looks like I’ll settle on a 3090ti, save a few quid in the process and this will see me through until the 4090ti and beyond.
Another one seeing the same thing but he updated from a 3090ti to 4090, no difference on a monitor but VR gets a good boost.![]()
Also watch for the tearing in VR (the side window area tearing like crazy every time he moves the view) and 3090ti beats the 4090 with DLSS on with a monitor..![]()
So I wasn't going crazy when I tested 3090 vs 4090 on a 7950x.
Another one :-
Comparing 3080 to 4090 on an Intel i9 10900K
I didn’t do thorough recorded benchmarks or anything, but I did do some baseline performance comparisons to see the performance difference between the RTX 3080 10GB and the RTX 4090 24GB on my existing system, with a 10900K, 32GB RAM. In heavily CPU-bound situations (settings on Ultra, poor...forums.flightsimulator.com
Basically zero difference on monitor users and only a benefit for VR and DLSS 3.0 doesn't work for VR DLSS2 does and that shows the uplift at VR resolutions but people complain the image is blurry too, because frame generation can't work on VR and never will frame generation will make a mess and make it unusable. Meeh ... Nvidia pulled a scam really with this as a selling point and DLSS 3.0 is not how people want to use MSFS in DX12 as DX12 is broken in the game and still in BETA, anyways more testing I need to do this weekend so far not seeing any changes from my 3090 to a 4090 at 4k with a 7950x at native DX11 and DX12 same FPS just less GPU utilisation on the 4090 ..because still cpu bound.
Another one mentioned before with a 3090 to 4090 :-
30xx Series Founders Edition
Tinfoil hat on. I get the feeling nVidia has released DLSS 3 a little earlier than it should have. They've used it to show the insane uplift in FPS for the new 4 series but obviously didn't highlight any of the issues it currently faces. Meanwhile, the sites/youtubers who've done in-depth...forums.overclockers.co.uk
10% faster in a synthetic benchmark so basically no quicker at all in real games.
The 3060Ti isn't exactly bandwidth starved in the same way the 3070 wasn't.
Also stating the new card is quicker than the A750 in 3Dmark is not really a massive win. I own a A750 and whilst it is faster than my 3060Ti FE in a number of synthetics it is currently getting pummelled in actual games. This may change in the future (although I doubt a role reversal) that is the reality currently.
Still funny to see this from a company who just done an embarrassing amount of back pedalling over their rebadged 4070 fiasco.
Not to mention 3080FE and then 3080FE LHR. And you can also chuck the 12 gig 3080 in there even though there was no FE model of that. But after all that our little brains can't process 4080 12 gig and 4080 16 gig.![]()
Yep, good feedback @Purgatory . Need them real world instances and not some company bar charts trying to sell their products to base performance on. 2X is suddenly now 65% in wider tests.
Not their first rodeo, nor second... They do these confusing naming quite often, though usually on lower shelf.![]()
Upcoming GDDR6X RTX 3060 Ti will be up to 10% faster according to benchmark leak - KitGuru
We've been hearing rumours for a while now claiming that Nvidia is going to refresh its RTX 30 seriewww.kitguru.net
From the company that claimed 2 cards with the same name was confusing......
So bloody frustrating, really would love a 3080 to replace the 2070 super I have, and then put the 2070 in my other 980 GTX system. But Car MOT must come first! The urge to spend is really bad lol
3080's should be around £400 now, 500+ is still way too much
They'll stay where they are until stock dries up, then after the 30 series is all sold out we might see a £50/75 drop, IMHO..
