No. Carrot ninja.Steven Seagal, Fruit Ninja ?
More like Under Siege 3: Russia specialSteven Seagal, Fruit Ninja ?
No blood, no gore, no bodies and no attack.
The Su-25 is fitted with the standard Russian K-36 ejection system which is zero-zero rated, so he should be fine. Probably a little winded, bruised and amped up on adrenaline, but otherwise fine.That's a very low-level ejection or bailout. I would not be surprised if the pilot had a broken leg. Staying in the middle of a field is not a good idea!
In June last year.It was from a training exercise - he hit a power line
Heard a rumour that AFU are using Maxim`s - WW1 trench style and we have a repeat of the Somme, this time its Russians dieing by the thousands.
Yeah, those old-school MGs were/are extremely well builtA water cooled Maxim might be just the trick when you’re facing wave upon wave of Kalashnikov wielding Lemmings coming straight at you.
In 1963 in Yorkshire, a class of British Army armorers put one Vickers gun through probably the most strenuous test ever given to an individual gun. The base had a stockpile of approximately 5 million rounds of Mk VII ammunition which was no longer approved for military use. They took a newly rebuilt Vickers gun, and proceeded to fire the entire stock of ammo through it over the course of seven days. They worked in pairs, switching off at 30 minute intervals, with a third man shoveling away spent brass. The gun was fired in 250-round solid bursts, and the worn out barrels were changed every hour and a half. At the end of the five million rounds, the gun was taken back into the shop for inspection. It was found to be within service spec in every dimension.
These days he's more Pork ninja.No. Carrot ninja.
They've certainly lost a lot as well, but since they've been rotating troops in and out as well as generally having better outcomes wrt to wounded I doubt manpower is their greatest concern.No one ever talks about Ukraine losses, I'm curious if they have the manpower to last a couple of years?
