Yes, spark not arc.That's one large spark right there on 12v aka an arc. Also as explained in my previous reply not the volts that matter but the amperage/current.
Yes, spark not arc.
Not exactly. You can get arcing on a high-current 12V circuit, but it happens because because there's enough inductance that trying to interrupt the circuit causes the voltage to increase high enough to break down the air. Or, in the case of that 24V (two 12V batteries in series) welder you posted, the current is high enough to vapourise metal, forming a conductive plasma. That isn't going to happen with any 12V connector in a PC.
Don't think i can get an aftermarket cable for my corsair AX1200 psu
Looks like cable mod no list my PSU on there website
This thread has been locked by the moderators of r/nvidia
New comments cannot be posted
All new post regarding adapter failure should be reported *here* where Nv will investigate each on a case by case.
New comments cannot be posted.
So is this another controversy around an NV launch that will end up soon forgotten? 20 series it was failing 2080 Ti's
Not read much on this but seems to be a bit of user error around install the cable. If you're going to bend it sideways along the length then yep you're asking for trouble. Do it as NV suggests and likely no problem.......
I don’t know how Jenson finds the time to run a multi-million $ company and post on here under a pseudonym. Only explanation surely?Oh yeah thats definitely it! It's such a non issue nvidia are looking into it and are contacting people who have posted about it. But for sure, it's all about the Jelly at not handing over £1700 for a gpu. I'm so jealous i didn't get the opportunity to do that, i woulda given them £1800 just for the "privilege" and let Jensen come plough the Missus for a few hours.
Jensen said it's such a huge issue that he will personally come to your house and crimp a cable Infront of you and then braid it with a leather jacket off his own back.I don’t know how Jenson finds the time to run a multi-million $ company and post on here under a pseudonym. Only explanation surely?
Jarred is more annoyed about bringing up Adapter Gate that AMD would advertise "AMD the safer choice" then the actual problem itself.
Sorry to see that mate. I am glad you took the time to do random inspections to catch it early though.Shaz12 said:I just took off my connector to take a look and I noticed a crack near one of the connectors which I am sure wasn't there before. I am putting my 3080 Ti back until I get the Cablemod cable next week.
who knew oxygen was flammableSorry this nothing to do with a 4090 but this guy had a real shock while using a can of air to clean his PC
Hmm what is wrong with it, looks fine to me,I just took off my connector to take a look and I noticed a crack near one of the connectors which I am sure wasn't there before. I am putting my 3080 Ti back until I get the Cablemod cable next week.
or so MLID claims
Nope, can't see it needs a better focused photoYou can see a crack in the plastic above the pin to the left.
I'm sure there is one but I can't make it out.
However the pins show no sign of heating at all, the sleeve will be compressed in the connector anyway and will form adequate insulation and location.
