No it doesn't it's much more robust than crimping and much better for higher loads. It provides a low resistance path.If you are saying that the way it is soldered in this particular adapter is better than crimping, you are the one with no clue.
And in molex connectors, soldering is typically not wanted in general - its screems amateur to say the least.
Crimping adds another potential local resistance and a local hot spot. The guy has no idea.
