The first one is from a time when PC Gamers had to make do with a PC case, not something that was designed to be aesthetically pleasing, the fact that there was a market for that had not yet been discovered, not like now where you can even buy mouse mats with rainbow puke in them.
Still, there is something about those old cases, they are not pretty and the inside of them never looked tidy as many component manufactures were experimenting with ascetics, like that Nvidia? CPU cooler.
Agree it was a different world then mate. I always had a plan to spray it a black colour but never did as was worried the plastic would look bad on the front as I saw people back then do it and looked worse than what they started with, needed a proper spray system and paint and a lot of time sanding.
As you see even with my current case I don't have glass side panels as not one to look inside the case and the RGB on any components is normally switched off was just for the pic the gpus and mobo was lit up. As you see I didn't even use the cable combs as I just tie wrapped the cables neatly as possible more function over looks really.
