Bambu X1
Don
OP
18 Oct 2002
Wargrave, UK
Will be interested in your thoughts, I think it does look a great printer but it just takes away the tinkering aspect which is what I enjoy the most.
I enjoy tinkering too, hence I won't be getting rid of either my large CoreXY or my tool changer. The Bambu is replacing a bedslinger that I built based on a Prusa Bear years ago.
Don
OP
18 Oct 2002
Wargrave, UK
Yeah, so I might have been a little premature. Happens to us all at some point in our lives.
The label has been printed but the shipment hasn't been handed over to DPD from the local warehouse yet. Maybe tomorrow.
20 Feb 2009
Not where I'd like to be
They do look impressive. My only concern is the amount if filament they appear to purge out when changing colour, some of the videos on YouTube seem to show a lot. If I wasn't set on a Voron 2.4 I'd be ordering one of these. Maybe I'll order one when they release their next model/version.
Don
OP
18 Oct 2002
Wargrave, UK
Yeah, the coloir change does waste a lot of filament. It's the same with any machine that uses a single nozzle for multiple colours / materials. If you want less waste then you need a toolchanger or an IDEX.
I have a Toolchanger and it's great when it works. Pain in the ass to deal with though.
My main reason for having this though is not multi-colour prints. It's to have 4 different filaments loaded and being able to choose at the time I send the print job what to print it with rather than having to go and unload / load filiament.
At the moment I've got it loaded with PLA, PETG, ASA, and soluable support material. I think that's what it will be set up with going forwards.
30 Jan 2007
PA, USA (Orig UK)
If i had the multi, the one material would definitely be for clean supports. Dissolvable material or similar
