That's good news! I hope to get my watch soon, but if it's like the Pixel 6 headphones saga, it might be around 45 days before I get it. I hope not!Battery life on the watch has now settled.
Took it off charge @ 6am, on all day at work on max brightness and AOD. Took it off @ 7.30pm
44% left. Happy with that.
I missed the post where you sold it but assumed when I'd seen you had pre-ordered one that you'd end up selling it then buying it again at some point
I think over in the states your provider will let you share a number on the esim at no extra cost but over here in the UK, they've taken it as an opportunity to charge extra for this 'feature'.So question with the watch - how does the esim work? Does it mirror the SIM from your phone?
I'm with EE on my pixel 7 pro (physical sim) - will i have to do anything?
Same with EE too. Seems like a con tbh.I think over in the states your provider will let you share a number on the esim at no extra cost but over here in the UK, they've taken it as an opportunity to charge extra for this 'feature'.
I think on Vodafone they want an extra £7 a month which is just stupid.
Edit: I just checked with Vodafone.
"The one number connectivity plan is £7 per month, as you'll have a separate number and can use the services even when you are away from your mobile phone"
What a joke!
Data and call functions.Yeah sounds rubbish. What do you lose out on if you don't bother and just link the watch to your phone via BT? Assume just ability to make calls with your watch?
What a joke!
I don't have esim on mine but can make calls with the watch - all through BT of course.Yeah sounds rubbish. What do you lose out on if you don't bother and just link the watch to your phone via BT? Assume just ability to make calls with your watch?
You can still make calls etc. It just means you need to be close enough to your phone for the watch to connect.Yeah sounds rubbish. What do you lose out on if you don't bother and just link the watch to your phone via BT? Assume just ability to make calls with your watch?
Thought that was pretty obviousYou can still make calls etc. It just means you need to be close enough to your phone for the watch to connect.
I've worked in IT support long enough to know nothing should be assumed to be obviousThought that was pretty obvious![]()
