Nice choice on the Duo Pro - I still can't decide that or a Bambino Plus burning also leaning towards the Duo Pro![]()
Trying a new roaster, interestingly the bags they're using don't have the CO2 valve. Anyone seen these before?
ok didn't know you can get £50 off sages, although I'd seen that for gaggia pro taking it to 379 which would cross-over with bambino+I'd seen Bambino Plus for 299 or something from one of the big retailers so about 50 difference if buying Duo Pro from Sage with discounts ?
Pretty much got the grinder and tamping sorted.
Any tips on frothing milk? I either get too frothy or just hot milk haha, I am after the velvety, microfoam look if possible.
If you like Silky Milky you need to learn from our mate Lance:Pretty much got the grinder and tamping sorted.
				Will take a look! Cheers.If you like Silky Milky you need to learn from our mate Lance:
LEARN TO STEAM SILKY MILKY IN 5 MINUTES!
I guess technically, the video is a smidge over 6 minutes, but the actual teaching part is 5, I swear!Hope you enjoyed the super speedy milk tutorial!Link to...www.youtube.com
				Yep, was going to recommend those twoI'm looking at the Hario Skerton, or the Hario Mini Mill.
Cheers, that's good to know. Is the mini mod the one where you use duct tape? I was reading a site about that yesterday.Yep, was going to recommend those two
I have a Mini Mill and there are a couple of simple mods you can do to make it much more consistent. I use that for pour over and electric grinder for espresso.
