- 27 Mar 2013
Should have got one before March then they were only 600 or so. There's no issue charge on a granny plug, I did it to start with but I limited it to 8A as I'd heard some bad stories. Obviously depending on how much driving you do, you might not be able to charge enough (I only do 32 miles a day so can go 4 days between charges using my 32 amp, but one of colleagues does 100 miles a day so he plugs in every day with a 32amp).I had a sparks in who reckoned the cable was up to 100amp.
To be honest though, car chargers are a total rip off and pretty crap still - and we are surviving on a 3 pin plug - so I might get consumer unit + an outdoor 13amp socket fitted and be happy from there.
. Might be easier converting to a hot water tank if you do have an electric one, I imagine changing the cabling from your box to the next step would cost a fortune.
