- 18 May 2010
- London
New drivers have solved the flickering issues in Elden Ring so I assume they are solved elsewhere too.
NVIDIA GeForce 526.98 WHQL driver download & Discussion
This new Game Ready Driver provides the best day-0 gaming experience for the latest new games supporting NVIDIA DLSS 3 technology including Marvel’s Spider-Man: Mike Morales, Warhammer 40,0000: Darktide, and the new update for WRC Generations – The FIA WRC Official Game. Additionally, this Game Ready Driver supports the launch of World of Warcraft: Dragonflight and the addition of DLAA technology to Monster Hunter Rise: Sunbreak.
Gaming Technology
- Introduces support for the GeForce RTX 4080
- Introduces DLSS Frame Generation support for VSync when G-SYNC is enabled
- Introduces support for HDR10+ GAMING standard
Fixed Issues in Version 526.98 WHQL
- G-SYNC logo is not displayed in the LG OLED TV menu when connected to GeForce RTX 40 series GPUs
- Uncharted: Legacy of Thieves Collection may crash when launched on a GeForce GTX 10 series GPU
- [QNIX QX2710/Fujitsu Siemens SL23T-1/Dell UP2715K/ HP Z27q] Unable to select the native resolution of certain monitors from the Windows display settings
- [Daz Studio] Application crashes after updating to latest driver when trying to run simulation
- Desktop Window Manager (dwm.exe) service may report significantly higher GPU usage on certain PC configurations
-Maxon - Cinema4D + Redshift3D vidmemory allocations cause TDR or Driver Crash
Open Issues in Version 526.98 WHQL
- Toggling HDR on and off in-game causes game stability issues when non-native resolution is used.
- [DirectX 12] Shadowplay recordings may appear over exposed when Use HDR is enabled from the Windows display settings.
- Older versions of Minecraft Java Edition show corruption on screen
- MSI Afterburner is not prioritizing GPU temp limit over power when selected in app
- [RTX 40 series] Metro Exodus Enhanced Edition may show random screen flash during gameplay
- [GeForce RTX 4090] Watch Dogs 2 may display flickering when staring at the sky
- Monitor may briefly flicker on waking from display sleep if DSR/DLDSR is enabled.
Release Notes https://us.download.nvidia.com/Windows/526.98/526.98-win11-win10-release-notes.pdf
Download https://us.download.nvidia.com/Wind...-win10-win11-64bit-international-dch-whql.exe
Can't believe this has appeared again, was an issue months ago before being fixed...
Hallelujah, why the hell this wasn’t there to begin with I’ll never know. Great having a high frame rate but then I would have to suffer from horrific tearing issues.
Honestly I find it just fine, I’m controller user so the tiny input latency is invisible, if you’re using a mouse then you can feel it slightly but even then it wouldn’t bother me.How do you find the frame generation?
Looks like it was related to the worse frame times with HAGS in Dying Light 2, as the issue seems to be gone now.
Vulkan frame times still slightly regressed (not related to HAGS).
I have noticed I have this - Desktop Window Manager using 90% GPU when I open task manager. Game performance seems fine but there has been some noticeable stuttering recently. Do you know if this actually an issue or just incorrectly reporting in task manager?
Seems games that support frame generation need updating to support vsync as it's still greyed out in games like Spider-Man and A Plague Tale Requiem the moment frame generation is turned on. Forcing vsync via the nvidia control panel still works as a temporary fix for now.
Before if I forced vsync on with frame generation the frame rate would be about the same as my refresh rate of 120hz so about 119/120fps, but with the new driver frame generation and forced vsync caps the refresh at 115fps.
This was exactly what I was looking for thanks @Neil79The latest DLSS for Warzone 2/MW2 is apparently a lot worse in quality and people are recommending downgrading it to 2.4.6
NVIDIA DLSS DLL 310.7.0 Download
This download provides various versions of NVIDIA's DLSS DLL for download. In this one file, which is bundled with all games that support NVIDIA'swww.techpowerup.com
Also NVIDIA DLSS DLL 2.4.13 is now available and might be worth a try?
Program Files (x86)\Call of Duty\_retail_ for MP and Warzone.
And in Program Files (x86)\Call of Duty\_retail_\sp22 for SP.
2.4.6 has been goated for a while now
