I wonder if the 6+2+1 VRM design would be enough for an 8 core Zen 4 CPU?
I've been hearing that a lot of AM5 boards have huge overkill VRMs - it's possible this is one that's actually designed for what you can put in it, rather than pushing for marketing numbers.
The specs say "60A power phase"; my uneducated brain suggests that is 360 amps, divide by about 1.4 for the voltage and potentially service up to 255W peak load. Although I suspect it will get hot and not be one of those boards where you can take the VRM heatsinks off and still run a 7950X
That said, that board is a bit stingy with USB on the back plate.
If I remember right, the Riptide is only a 6-layer PCB, which mostly means you can't make assumptions about it based on the performance of "similar" ATX boards, which are all 8 or 10 layer. I'd wait for reviews on it myself, but I suspect its weak spot won't be the VRMs. I'm not sure any AM5 board has weak VRMs. Which might explain the costs!
