Man of Honour
- 5 Jun 2003
- Falling...
The politicians have stated that this is a long term project with benefits due to be accumulated over several decades. Some some up to 100 years. It does seem to make it less appealing but at the same time there are some other factors to consider which don't sound as sexy but are probably worth mentioning.
Freight - it should in theory remove thousands of trucks off the road and increase the FMCG industry. That should in theory have a net benefit (carbon and so on), improve road networks and better transport hubs. Imagine I guess smaller electric van distribution hubs at either end would be far better than 10s of thousands of 40 tonne trucks. I mean heck 1 train alone can take over 50 truck's worth.
SMEs engagement and development. Stimulating innovation and knowledge and development in a somewhat old fashioned sector. I believe Hundreds of SMEs have been engaged and grown as a result. They could then export their capabilities internationally? I speak from personal experience as I've helped over a dozen SMEs engage with HS2 and over half of them have doubled in size since a d doing really well.
Apprenticeships. I think they're due to achieve their 1000th apprentice soon which is actually pretty cool.
Employment - 30k+ jobs is not to be sniffed at.
Social value impact - but that I guess is a more long term issue of course.
I think there's also an opportunity to create a new standard for rail in the UK if the ORR and DfT allow for the changes and modernisation of the rail network which they seem quite slow at allowing to happen.
It could also take a lot of the burden of the main routes allowing for better local and regional rail services to be improved?
However it is all quite hard to be sure as the economic model keeps changing and although all the independent papers do state overall value it is nonetheless a very expensive project and seems a little disproportionately costly. I think this is mainly down to politics rather than anything else.
Though in comparison rail Baltica is seemingly only going to cost around £6bn and is a significantly larger more complex project.
That said the new rail connection programme in Canada is earmarked at $75bn in total! Still less than HS2 though.
The Etihad rail project is over. $14bn but a lot simpler than HS2 but does have to contend with sand and heat.
Infrastructure is expensive but it does stimulate the economy. However I am torn at the cost of HS2, especially now the project has been completed butchered - I think if it was the cost and actually went all the way to Scotland then I think that would be justified.
