No issue with liquid metal going off afaik , I had it on the 3090 strix for around a year and temps remained perfectHaha brilliant!
What’s the longevity of the Liquid Metal like?
Block and system looks incredible btw!
hows it an issue though? 600w is for overclocking which gives literally almost no gains anyway and the majority of people are setting the power limit below 100% with 100% being 450wattno nothe cablemod 3 x 8 pin is perfect and will do 600w , the issue is if using the supplied 4 plug by nvida and then only using 3 of the 4
Haha brilliant!
No issue with liquid metal going off afaik , I had it on the 3090 strix for around a year and temps remained perfectAlso all PS5 have liquid metal as the TIM and pretty sure they are expected to last 5 years + without ever being opened up
Certain games will happily use over 500W ( Quake 2 RTX & Metro Exodus ) What is cyberpunk power usage at 4k native with RT ? COD MW2 will be power limited at 450w in the campaign ( >500w) , these is a use case for the 600w . While most people are happy to have it at 450w or less having the option to have more if needed is better especially if the card is intended to be used up to 600w ie the FE or Asus cards . Having the card on 3 pin will limit him to 450w , the card will work as intended but wont be able to increase the power limit beyond 450w.hows it an issue though? 600w is for overclocking which gives literally almost no gains anyway and the majority of people are setting the power limit below 100% with 100% being 450watt
Sony should use some nail varnish on the PS5 as well rather than that stupid black take they useThe liquid metal on the PS5 is in a sealed chamber so it's a bit different. I have seen a couple cases on Reddit of overheating PS5's caused by the seal failing and the Liquid Metal leaks out
so your basing this on hearsay or what?Certain games will happily use over 500W ( Quake 2 RTX & Metro Exodus ) What is cyberpunk power usage at 4k native with RT ? COD MW2 will be power limited at 450w in the campaign ( >500w) , these is a use case for the 600w . While most people are happy to have it at 450w or less having the option to have more if needed is better especially if the card is intended to be used up to 600w ie the FE or Asus cards . Having the card on 3 pin will limit him to 450w , the card will work as intended but wont be able to increase the power limit beyond 450w.
Keep in mind thats raster performance. Its not using the card fully, that's why he mentioned RT games as they will use more power.so your basing this on hearsay or what?
527watt = 130fps
375watt = 120fps
so much more power not even a 10% difference
Generally speaking it lasts forever. Problem is, in order for it to last forever, you need to apply it twice. So basically you apply LM, and then a couple of months or weeks later you go back and reapply. Now you are good to go.Haha brilliant!
Recommended to replace liquid metal once a year. All that will happen is you'll notice the temps start going up slowly over time and you can just replace when the temps are too high for your liking, so you can just leave the Liquid Metal for as long as you like until the temps go up
527watt = 130fps
375watt = 120fps
The RTX 4090 Power Target makes No Sense - But the Performance is Mind-Blowing
Support me on Patreon: https://www.patreon.com/der8auer---------------------------------------------------------Save 10% on your iFixit purchase: DER8AUER10h...youtu.be
maybe in actual rendering/cuda stuff it's worth going higher than 70% power draw, in gaming why bother unless your cold?
Shame thread starter didn't update the original post with good info.
like
Oh I've never heard of having to apply it twice ... personally i just done it the once on my Strix and was solid throughout the year temp wiseGenerally speaking it lasts forever. Problem is, in order for it to last forever, you need to apply it twice. So basically you apply LM, and then a couple of months or weeks later you go back and reapply. Now you are good to go.
yeah I was trying this with modern warfare2. at native res with DLSS on I get this awful shimmering outline around player models. But with DLDSR on and DLSS on thats completely gone, I'm maybe 10 fps down overall. but quality defo looks betterIt has a larger impact depending upon the game. Cyberpunk sees massive improvements in shimmering which is a key issue with DLSS as the AI gets more pixels to work with but on games like God of War and Dying Light 2 it isn’t as huge.
The best way I would put it is the image is more crisp and stable any while you may not notice much improvement right now, try playing with for a few hours enabled and then disable it. You will notice the image feels lower resolution easily.
They are probably hoping people will get fed up of waiting and buy the 4080 insteadnot had any notification of 4090 FE stock in a while, whats going on there lol
With MW2 and DLSS i find that turning the sharpening down to 60/65% cleans up the image a lot . For some reason they choose to set it to 80% as standard which as you have noticed leads to some shimmering artifacts around the character most noticeable in the lobby , sharpening was always set at 50 in previous games so no idea why they set this one so high but you have the option to set it back to 50 if you want and still looks goodyeah I was trying this with modern warfare2. at native res with DLSS on I get this awful shimmering outline around player models. But with DLDSR on and DLSS on thats completely gone, I'm maybe 10 fps down overall. but quality defo looks better
whats that supposed to show? all it shows is the card can use over 500watt which is not what I was even talking about.Yes all based on hearsay , i make this **** up as i go along![]()
Its shows what i was referring to in my original comment that the card can and will happily draw over 450w when needed in certain games and you asked if that was based off hearsay to which i am showing you no it isn't . I never said you will get massive gains going from 400w to 600w but you will lose performance in games that need to use more as once you are power limited the core will downclock itself and you will lose performance to a degree . As i put why would i want to cap performance when i am not even hitting the refresh rate ? If you are happy to do so good for you but having a card limited by power is not something i am interested in and neither is the guy who was originally asking about the cable.whats that supposed to show? all it shows is the card can use over 500watt which is not what I was even talking about.
it doesn't show you getting massive gains from going from 400 to 500+
btw the difference between RT on and off in cyberpunk barely effects the watts
