LG's 27 inch 240hz gaming monitor is here and it's $999usd
www.lg.com
27" UltraGear™ OLED Gaming Monitor - 27GR95QE-B | LG USA
Discover the 27" UltraGear™ OLED Gaming Monitor that features 240Hz Refresh Rate and 0.03ms Response Time. Find reviews, specs, and more for 27GR95QE-B.
PICTURE QUALITY
- Screen Size
- 26.5"
- Display Type
- OLED
- Color Gamut (Typ.)
- DCI-P3 98.5%
- Color Depth (Number of Colors)
- 1.07B
- Pixel Pitch (mm)
- 110.8 PPI
- Response Time (GTG)
- 0.03ms (GtG)
- Refresh Rate
- 240Hz
- Aspect Ratio
- 16:9
- Display Resolution
- QHD
- Resolution
- 2560 x 1440
- Brightness
- TBD
- Contrast Ratio (DFC)
- 1500000:1 (Typ.) TBD (Min.)
- Viewing Angle
- 178º (R/L), 178º (U/D)
- Surface Treatment
- Anti-Glare, Low-Reflection of the front polarizer
INPUT/OUTPUT
- HDMI
- Yes x 2
- DisplayPort
- Yes x 1
- Headphone Out
- 4-pole (Sound+Mic)
- USB Up-stream
- Yes (1ea/ver3.0)
- USB Down-stream
- Yes (2ea/ver3.0)
- SPDIF out
- Yes
POWER
- Type (w/ Watt):
- External Power (Adapter)
- Input
- 100~240V (50/60Hz)
- DC Output
- 19V, 5.79A
- Power Save/Sleep Mode (Max)
- Less than 0.5W
- DC Off (Max)
- Less than 0.3W
- Power Consumption (Typ.)
- TBD
- Power Consumption (Max.)
- TBD
SPECIAL FEATURES
- NVIDIA G-Sync™
- G-SYNC Compatible
- Adaptive Sync
- AMD FreeSync™ Premium
- Black Stabilizer®
- Yes
- Dynamic Action Sync®
- Yes
- Crosshair®
- Yes
- Smart Energy Saving
- Yes
- Reader Mode
- Yes
- H/W Calibration (True Color Pro)
- Ready
- Color Calibrated
- Yes
- OnScreen Control (OSC)
- Yes
- HDR (High Dynamic Range)
- HDR10
- HDR Effect
- Yes
- Auto Input Switch
- Yes
- FPS Counter
- Yes
- 4-Side Virtually Borderless Design
- Yes
- User Define Key
- Yes
- VESA DSC
- Yes
- VRR
- Yes
- RGB LED Lighting
- Hexagon Lighting
- True Color Pro
- Yes
SOUND
- Speaker
- No-built in speaker
- DTS HP:X
- Yes
DIMENSIONS/WEIGHTS
- With Stand (WxHxD)
- 23.8" x 22.6" x 10.2"(Up) 23.8" x 18.3" x10.2"(Down)
- Without Stand (WxHxD)
- 23.8" x 13.8" x 1.8"
- Shipping Dimensions (WxHxD)
- 31.8" x 7.1" x 20.9"
- With Stand Weight
- 16.2 lbs
- Without Stand Weight
- 11.1 lbs
- Shipping Weight
- 24.3 lbs
STAND
- Tilt(Angle)
- -5º ~ 15º degree
- Swivel (Angle)
- -10º ~ 10º degree
- Height(mm)
- 0 ~ 110mm
- Pivot
- Counterclockwise
- Display Position Adjustments
- Tilt/Height/Swivel/Pivot
- One Click Stand Set-up
- Yes
- Base Detachable
- Yes
CABINET/ACCESSORIES
- Power Cord
- Yes
- Remote Control
- Yes
- Display Port Cable
- Yes
- HDMI Cable
- Yes
- Calibration Report (Paper)
- Yes
- Others (Accessory)
- Cable Holder
- USB A to B Cable
- Yes
WARRANTY/UPC
- Limited Warranty
- 1 Year Parts and Labour
When the 4K 32" version comes out I will have a hard decision to make. Does it spark joy?
I like the look of it though.
