Modular.
23 Apr 2010
West Sussex
Hey everyone. Over the past few years I have let my modding slip. The reason for this is that it always took my rig out of commission. This was OK when I wasn't gaming much, but I am now. It is just too much of a ballache, so I could not do anything even approaching extreme. Just vanilla builds and upgrades.
So, I am going to enter the arena once more.
I have had this mad idea now for years about doing a scratch build. Every time I have started designing it though it has made me realise that I don't have the tools and machines in order to achieve what I would want to do. Maybe I was biting off more than I could chew? IDK.
The last build I did that was even slightly extreme was the Stryker build last winter. I like to do PC stuff in that time, as most of it can be done in the warm. Sadly again I needed the rig working whilst I was doing this, and as such a custom paint job was about the best I could do.
TBH? it was pretty cool. The paint came out really well. The only problem was that it wasn't cool. The temps on it were bad. Like, really bad. I never quite worked out why, but I think it was the radiator loaded in the side.
It just couldn't breathe, and was not cooling. It also blew all of that hot air into the board, which made the CPU really hot even at idle. As such the GPU suffered. The thing is, I have had these rads and pump in another build and it was proper cucumber.
The GPU never went over 46c. In the ITX build? it was struggling to stay under 70. So something was very wrong in there. Like I say, I think it was simply the rad in the side turning into a heater rather than a heat exchanger.
So, once again you can always count on your friends to give you bad ideas. Cheers, Cenedd ! you git :D
A couple of weeks ago Gareth asked me if I wanted his old crap. Usually I would say no, but he had a 2600k and I have a NAS with a 3470 in. That needs more threads. So I said "sure !". What I didn't realise was this old crap had a really nice CPU block on it. In absolutely pristine condition.
Like seriously, you would never even know it was used. I took apart the above ITX build and put it into a way better case (see the Mini Me thread). The 2080Ti was removed and drained and dried, and then stashed away along with all of the equipment. But I was getting nagged by my conscience. "Come on man, now is the time !".
And so I came up with the idea of Modular. A name that basically says it all.
I know that stuffing water cooling into a hot box is a really bad idea. You live and learn. So what if I kept the cooling separate? So I started designing rad boxes, etc. I then found a Phobya dual 240 rad box on the bay, but he wants too much for it (about £70). Thing is? it is not enclosed either. I then struck upon the idea of looking for an ITX case. And I found one.
"Does it hold a 240 top and bottom?" check.
"Is is very well vented?" check.
And so that will become my cooling box. In there will be two Bitspower 240 Leviathin thin rads, a DDC pump and top, a small res and obviously fans. I then hit upon the realisation that of course this box would have no power in it. And I don't want to fix a hulking great PSU just to run a pump and some fans. So I thought "what would be the easiest and most affordable way to power this contraption?" and then it hit me.
No controller needed, full voltage control from 12 down to 0. No fans on it either, so no extra noise. And it was cheap, £12.
So, the idea here is to build that first. That will be the first part of Modular. Once that is done? I can start looking into what I want the second unit to look like. Obviously it will have my 2080Ti "McDodgy Edition" in it, that has dodgy VRAM. However, I am sure if I can wind the temps down on it it still has much more life left in it. It was just in that specific application it wasn't happy.
Of course box two will be ITX. I want to make that as small as humanly possible. The main box (above) will have the DDC in it. With a top and res. However, just to make sure the flow stays steady I have this that will be in the hardware box.
Along with this diddy little top.
I then utilised Black Friday to buy some hardware for the second box. I chose this board specifically because it has Thunderbolt. Meaning if in the future I want to add on more? I can grab an external GPU box.
Of course I needed a CPU too. Grabbed a 11400F also.
I have plenty of DDR4. I even have some in white.
At home I have a 850w Dell PSU. It works perfectly. Only thing is the cables are crap, so I have been using it as a test unit. However, I recently bought a SF kit for my EVGA PSU and here is what was left. Seriously, there are about 12 8 pin PCIE power cables in there.
Cenedd showed me the best depinning tool ever, so I am going to take those home with me and pin the Dell PSU with all of the spare cables. I will paint the body of it at some point, as it is stainless silver.
Obviously for right now the plan is to just build and mod the cooling box first.
Well, I'd rather see it put to good use than sit in a cupboard gathering dust. Good job that I've not just managed to brick my motherboard now that I've removed all spare parts from the house *facepalm*
That sounds perfectly in line with our luck.
Totally.
I just pulled the trigger. I was going to wait, but I think it ends soon. Waiting would have cost me, a lot, so I grabbed them now.
They were the cheapest available @ £34.99 each. 500gb, like. Oddly the model below also costs that. These do 3400R. The model below does 2400. Still, I am not complaining.
Any other storage will be TB.
Update one point five. The case.
So obviously it arrived. I should have left it until I return, but you know how that goes. It doesn't.
So I got it out. I then began removing the detritus. Which continued. I was also enormously happy to find that the badge on the front was not mounted. IE, it wasn't pins with holes drilled into the case. It was just literally a sticky badge. Good, off it came.
And said detritus.
I must mention that it is very tinny and flimsy. However, given I will have no interaction with it once it is done, being a "dumb" box it doesn't matter, because it looks friggin awesome.
It still needs to be modded a little more extensively. I need to drill out 6 rivets so I can remove the PSU holding plate. It gets in the way of the rad and fans in the top. Once that is out though? yeah, very simple mod.
Update two, the power supply. And other assorted bits.
So today the SSDs arrived.
I came home, and had a dig in the stash. Soon found some goodies.
Most importantly the PCIE 16 ribbon and DDC pump bracket from my Lian Li 012.
I also have this left over from Mini Me (Q58) and I think I can use it.
OK, so over to our victim. One 850w Dell 80+ Bronze PSU.
It's not pretty. I also hacked in two wires so I could jump start it etc. So let's fix it. First we sit and depin all of the Super Flower cables.
And then we start gleefully swapping them..... Until we hit a road block. They are not all straight cables. Some are doubled FFS. Now I had already decided to do one half of a connector green, and the other black. Little did I realise this would work out in my favour as I will explain shortly. So there was lots of this.
And eventually we were chicken on a bear.
I will cable tie it together in increments to make it stay in the new shape. Now, let us go back to what I was saying about how I got lucky. I decided to do the green first. No cable in the green row is doubled. They are all on the black half. Meaning I could do this.
Without completely ruining how it looks. Obviously I do not have bright green heat shrink....
And with that I am quite happy. My hands are not. Very sore.
I shall pick up tomorrow on the other cables, as I noticed a lot of those are doubled too. Oh joy !
If it's 80+ Bronze it can't be that old...so how have Dell managed to make it look like it's from the 80's? ...and more importantly perhaps, why?!
Looking a lot better already. :D
2015. That was when I bought the Area 51. That said it's had about two hours use total in all that time.
It's getting custom paint, so don't fret dear boy.
The pics of the build in OPs post are incredible! Thanks for sharing
Wait until you see this one.
I still have that chassis. One day I will get the carcass powder coated and do it better. Mind you what am I saying? I still have every case I've built in lmao.
Update two point five. We have finished wiring.
It is messy. However, I have now designed the case layout in my head and you will not see any of it. Well OK, you will see the GPU cables but they are perfect as I realised the doubled cables in those were grounds, so I made two 8 pins going into 4 connectors (the PSU had 4 8 pins). So no doubling was required on those.
I have also bought this for my 2080Ti.
You will see why in a future update.
Update two point seven five. More PSU antics.
There were two ways you knew this unit was on. One, it clicks loudly when it starts (relay) and secondly you could hear the whoosh. It never bothered me, because within two days of buying that new PC in 2015 Tom Logan sent me a AX1200. So when I said it has had about two hour's of use at best? I meant it. I have only used it for firing up pumps when building loops independently of the hardware.
OK, so I took it apart. DISCLAIMER. DO NOT TAKE PSUs APART IT IS VERY DANGEROUS. They store voltage for a long time after being powered down, which in my case was just yesterday. YOU HAVE BEEN WARNED.
First thing I noticed was that the fan had a plastic air guide on, but also teflon tape all around the outside. So, I replicated that.
Adding my own tape around the chassis of the fan.
I then put it back together and tested again. Ahhhh, bliss. You literally have to pick it up and put it to your ear now.
BTW that Deluxe Halo (alu) hanging around in the pics is going here, sans the RGB.
I just want to make the body of the PSU look a bit more interesting. It will be getting painted, so bear that in mind.
Update two point nine. Nine nine nine, nine nine nine nine.
OK so I found some nuts and bolts. So I made the halo permanent.
Next step on the PSU is to strip it (that will be fun, it's modular !) and paint it.
OK so it is time to talk about the GPU. I originally bought it cheap about two weeks before the 3080 launched. Seller told me it had VRAM issues, which was fine considering how cheap it was. I never found those issues in the original loop. It all worked fine. In the small rig though it was getting too hot, and thus displaying issues.
A lot of the problem was the back of the card. It doesn't matter how much cooling I threw at it the back of the card was soaking up heat. Which does not help the VRAM at all.
So, as I posted, I bought a new back plate.
And I will now explain why. The one on the card is stupid. Has RGB, etc. It is also angled and not flat.
So now you are probably wondering why I care. Well, the answer is simple. I need a flat back plate. I need it because when I bought the card it had this on it.
And everything else in the rig was Bitspower. So I fancied treating myself. To this.
But also because it saved me taking the Barrow apart and cleaning it out etc etc. I was being lazy, in the best way :D
So, when I was digging through the cupboards doing my almighty clearout a couple of weeks back (which is ongoing) I found it. The Barrow one. Which got my brain going. What if I had the cold plate milled flat, and then attached it to a back plate?
Water jacket. It will also alleviate the biggest problem the card has, heat. Plus it also allows me to cram it into the smallest enclosure possible without worrying about it frying.
The Alphacool cost me a tenner, and comes with pads to surround where the VRAM and core etc go.
The only hard part? is how to attach it. I have a feeling I will be buying some thermal epoxy....
I am also going to have the total waste of acrylic machined off it too, so even flipped it can be centred on the hot part.
Update three. Materials and hardware.
So to finalise the spec of the build I had to take apart my backup gaming PC here at home. It has my old trusty Threadripper in it and too much RAM. I built a NAS with it a while ago and made it a bit silly. So, I removed it and recommissioned it as a gaming PC with my 2080Ti Kingpin in. Just incase I have issues with my main PC. Or, need to do work on it etc. I did have it on the TV for a while, but now I don't have room so I will be setting it up in the bedroom soon for winter. Especially now that I have stopped using my Xbox.
Any way, it had 64gb RAM in it. Two quad kits. I bought one, and then my mother got an Amazon voucher when she switched internet and gave it to me for setting her up, doing the switch etc. So I grabbed a second set. So yesterday I had to pull out the four white DIMMs.
That is another reason I went with Intel over AMD. Because the board was so much cheaper, and the RAM I have is "only" 3000. Which on Intel won't matter at all.
So that is the spec of the rig. As I mentioned I have gone over some designs in my head and pretty much have it nailed. I do need exact sizes, which is why I haven't put mouse to Photoshop yet. However, I did notice a cracking deal on some acrylic.
The last time I bought a sheet of A3 in 5mm it cost me £8. That was in 2015. These cost me £8.40 each and I have bought 5. The next best price was £14 a sheet.
Total cost £44. That said I do expect to maybe ruin at least one, so that was why I bought extra. You will see why in a upcoming update.
Talking of which there probably won't be any for about a week now.
