Just going to play devils advocate here... Since buying and using this CPU - God knows how many year ago - I've never see it significantly pushed by any application/game?noob overclocker here after a bit of advice, ive got a 4790k and use the turbo overclock in the bios with an air cooler, the only game i play is arma that is a cpu hog so i want to push the cpu a bit further if possible, i was looking at a corsair h110i or h55 aio cooler, would i be able to hit 4.8 with this fan or do i need a full watercooled setup?
cheers lads
And I bought my system and cooler with the notion of allowing it to be overclocked, but in truth with it seemingly just needing that overclock, I'm more than happy to let it run at stock generally with the fans basically idling nice and quiet, and the CPU still running in the 50s...
My fans only ramp up high 50s and then into the 60s... So most of the time the CPU/case fans are idling.
eg: Here's an old example, but I rarely see my usage (& temps) much higher than this. It's the GPU that seems to get the "hit":-
My 4690k needed 1.3v (IIRC) for the same speed. No crashes/BSODs yet (touches wood) and I look forward to searching for 4.6GHz and beyond.
