for sure. some recent monitors have pushed £3000 too (e.g Asus ROG Swift PG32UQX)...£900 isn't too bad, relatively, i don't thinkLol you're forgetting the days like the acer x27.. I paid £1600 for a 27 inch led.
I’m interested in this one - I don’t really want a screen bigger than 27-18 inch tbh. I find them overwhelming otherwise. So far I haven’t had any luck with IPS, always trigger migraines. So hoping OLED at this size and resolution will be pretty spot on for me - despite it being very expensive.
You're dreaming dude, £1100+ easy.£900 for 27" what crack pipe LG smokingI like the look of it though.
For this 27" or the ultrawide version?I was wrong
LG just made a surprise announcement; the monitor goes on pre order on 12 December and deliveries start on 28 December
I value contrast very much and black must be black and not grey. Another IPS issue are the IPS bleeds which is very annoying when there are dark scenes in games for example.I’m interested in this one - I don’t really want a screen bigger than 27-18 inch tbh. I find them overwhelming otherwise. So far I haven’t had any luck with IPS, always trigger migraines. So hoping OLED at this size and resolution will be pretty spot on for me - despite it being very expensive.
Truely remarkable when using it at nights for example.For this 27" or the ultrawide version?
Yep, LG has updated the page. I wonder, what about us Europeans and GB? Probably later which I hope not.The 27inch
27" 1440p 240hz is perfect for most people. IMO there's no need for 4k. Each to their own though!£900 for 27" what crack pipe LG smokingI like the look of it though.
Not only that, it uses a lot of more power too. More than 42C2. Not sure what's going but it looks to be a very disappointing. Still curious on what Evil Geniuses said. Or they've been bribed?LG releases brightness details for SDR
The monitor has a max SDR brightness of 200 nits and it's achieved with windows under 25% size. At 100% window size max brightness is 120nits.
Compared to QD OLED monitors which have 250 nits at 25% window and 250 nits at 100% window.
Meaning users will see significant dimming in normal desktop use of the LG monitor. LG has yet to release the HDR specs
Reddit - Dive into anything
www.reddit.com
Even if that 120 nits is enough, having to use high brightness setting to achieve that means putting lots of stress on OLEDs and burning through panel's endurance at faster pace.The brightness is high likely not really an issue for me because my room is fairly dimmed.
Didn't LG give "suggestions" for LCD monitor review to Hardware Unboxed year or two ago?Or they've been bribed?
Trying to turn it around to look positive for LG, aren't we?Its likely the opposite - they are probably limiting max brightness in order to protect/extend the oleds emitters lifespan and mitigate against burn in.
