It takes 3 times the electrical energy to produce hydrogen from water using solar/ wind.Efficiency doesn't matter when you have an unlimited supply.
The same for batteries and certainly more so. Batteries are made out of finite resources so the cost will be only one of the problems
Geothermal and hydroelectricity (which is what those countries rely on) are very stable and controllable sources, so not really comparable to wind and solar. They are also very dependent on the right geography and geology.We are not using even a fraction of available renewable energy sources and we are already using a very inefficient and more importantly non-sustainable way of producing electricity.
There are already countries that meet their energy demand from renewables so even existing technology seems to suffice.
100% renewable energy - Wikipedia
en.wikipedia.org
I thought tidal power is reliable.
No sacrifice of land, can scale up easily, etc.
Big plus when you are surrounded by the ocean.
We are not using even a fraction of available renewable energy sources [..]
You misunderstood the "available" bit
although you have accepted that we are not using tidal power yet? Doesn't add up. I am sure you are aware we have been using tidal power for decades in this country and we are in the best position in the world to harness this energy source. Not a dream - it is here already.
You also seem to miss the point about the cost. If there no other option cost is not part of the equation. Scarcity drives cost and I am sure you agree that fossil fuel will become scarce as the supply is finite.
Less people, a lot less people, stop dancing around what the real problem is!![]()
They are available for decades. In France since the 60s and producing 600MW. This is from a single, "old" power station.No, I didn't. You are talking about theoretically usable renewables. But they're not actually usable, so they're not available. Even if you count unusable resources as available, they're still irrelevant.
Test facilities demonstrate what is feasible. The estimate is that a single barrage could supply 7% of total UK energy needs.There's a 2MW (note that's megawatt, not gigawatt) tidal power station that was opened last year. That's it. It's only a test facility and of course the "2MW" is a nameplate capacity and those are meaningless for renewables. 25% is considered a good load factor for tidal. So the one and only tidal power station in the UK (which has been open for 1 year) probably averages about 500KW.
Eventually, yes. But that's irrelevant as I'm not arguing for fossil fuel to be used indefinitely.
Also, cost is always part of the equation. Especially when there are different options with different costs.
Impossible is not something that should be used as an argument. I guess you are more like people that did not believe that ships made out of iron would floatYour preferred course of action would collapse civilisation and kill billions of people. I consider that to be a very high cost. You seem to miss the point about the continued existence of human civilisation. You also seem to miss the point about it being impossible to implement your ideas, which are based on lack of knowledge and require ignoring most of what's written when replying to it.
Which might be why "renewables advocates" are advocating plans that would kill billions of people. That would certainly benefit other animals and plants in the long run.
We don't have volcanic hotspots to easily take advantage of like iceland does, and although there are some trials and there might be potential to expand geothermal generation, it will likely be more difficult and expensive in the UK due to the limited number of suitable locations and deeper depths we'd need to drill to.
Further large scale hydroelectric developments aren't really possible in the UK, at least without huge sacrifices of land and environment. Small scale schemes might be more feasible, but then they do lose some of the advantages of large scale hydroelectric dams, and can have other negative environmental impacts too.
Not sure what you mean about our current electricity generation being inefficient? Most plants are highly efficient.
The Severn can supply 5% of our countries electricity if they were to use the tides for power. IIRC it is the biggest source of tidal energy in the whole of Europe. Equivalent to several Nuclear power stations and is clean. It would create massive job opportunities for Wales as well but the government couldn't care as it has got nothing to do with London and rather waste billions on HS2.
Guessing you mean one of the barrage schemes? The Severn is probably the best case scenario for tidal power in the UK, but have to remember it is still intermittent (if very predictable) so storage or other generation capacity would need to be available. There would be big environmental risks too (the thought of all the assessments they've have to do, the uncertainty involved, and all the different local objections there would be make me dizzy just thinking about them...), and maybe with good design this can be avoided but tidal systems do have a bad reputation for being easily damaged and a bit unreliable...The Severn can supply 5% of our countries electricity if they were to use the tides for power. IIRC it is the biggest source of tidal energy in the whole of Europe. Equivalent to several Nuclear power stations and is clean. It would create massive job opportunities for Wales as well but the government couldn't care as it has got nothing to do with London and rather waste billions on HS2.
Plus it's still pretty tricky to come up with a design that can survive the kind of places that can generate large quantities of Tidal power and generate energy consistently (Not having to be turned off / "parked" during heavy seas etc..)
This is one of the big problems facing both Tidal and Wind power, as the available energy increases (due to stronger tides / winds) the more likely they are to have to be put into "weathervane mode" and not generate anything, for fear of them being destroyed from rotating too fast.
Hydrogen spring into mind... so storage or other generation capacity would need to be available.
I am sure having a solution that if damaged does not make a whole region uninhabitable for centuries is a preferred option for any person living in that area.There would be big environmental risks too (the thought of all the assessments they've have to do, the uncertainty involved, and all the different local objections there would be make me dizzy just thinking about them...), and maybe with good design this can be avoided but tidal systems do have a bad reputation for being easily damaged and a bit unreliable...
I agree that the government is too focused on London, but I don't think that's the full story here, given there are plenty of other electricity generation projects in progress. Also London needs electricity as much as anywhere.
I'm not necessarily against that scheme per se but it's not a panacea for a 100% renewable future. Also 5% is still nowhere near the potential of wind and solar if a 100% renewable future is what you want, which while being more variable also benefit from ever-dropping costs (while tidal lagoon / barrage costs probably won't drop that much with experience as they're mostly just big civils projects).
Imo Swansea lagoon should have been built as a proof of concept type thing, and after a bit of operating experience might be in a better place to decide whether to go ahead with a full barrage.
