- 24 Sep 2013
- Exmouth, Devon
I am contemplating buying a 4090 gpu to get the most out of the VR
looking At what’s in stock the cheapest is the PNY and the Zotac, but boost clock for those are 2520mhz compared to some which are 2640mhz (for an extra 3-£400)
will the higher mhz make much of a difference, or could the PNY be o/c to match?
just not sure what my best bet is
All cards boost waaaay over their advertised max boost anyway - so it becomes a bit of a silicon lottery even without overclocking. My Trinity OC model has an advertised factory boost of 2535Mhz but out of the box sits at 2750Mhz with no overclocking. 2900 with a simple OC on the core. SOme undervolt to get 99% of performance with a decent reduction in power draw making the card more efficient and not burn so much leccy as it's become very expensive.
Warranty when spending this much on a card was my top priority. Zotac are the only manufacturer to offer 5 years but some people have had noisy fans from the Zotac. Mine was until I changed the layout in my case and inverted the card.
Only reason some will purchase the top top cards are benchers who want the best silicon to get the highest bench scores. There used to be a few quid between the cards. Now this is £100's between models. Pointless as a gamer - you maybe able to measure the difference - but never 'feel' it in game.
