- 24 Mar 2011
- Cambridgeshire
CCD1 showed a maximum of 90.5 C, whereas the CCD2 screenshot shows a maximum of 85.0 C, but at a lower frequency (4536 MHz vs ~4668 MHz). Some variation in CPU temps is expected, but given the reduction in clock, the temps seem probably about expected. I don't think it suggests any problem with CCD1 other than your getting to enjoy PB2/PBO in all it's glory (thanks AMD!)Temps way lower on CCD2
I haven't run P95 for a very long time, but I did a test on mine just to see. I think I used the same settings (1344k FFT, AVX2 enabled, 2 cores).
Hwinfo
Looking at the data, it appears I'm getting about an extra 40-50 MHz. Peak CPU temp was 68.1 C, settling in to ~67 C after a minute or two. I didn't close any background tasks so my CPU load was a little higher at ~2.8 average cores, but average core power was still only 52 W (looks to be about 20% lower?).
The difference is I have PB disabled and I'm using profile switched undervolts instead. Given the 20% lower power, more clock and 20 C lower temps, you probably see why
