Do you still use 4 cables ?mainly cause the cards are clocked to **** before they leave the factory so the gains you get at home are minimal to pointless, normally with ampere at least you bring the voltage down and clocks up to still get 90% performance for 30-50% power reduction
3.015Ghz looked cool on the benchmark graphs and the scores were technically higher, but my VR headset runs at 90FPS and the uplift isn't enough to change any setting in the sim I also tested.mainly cause the cards are clocked to **** before they leave the factory so the gains you get at home are minimal to pointless, normally with ampere at least you bring the voltage down and clocks up to still get 90% performance for 30-50% power reduction
yes u can just use 3 cables, you will get 450W. 600W with 4 but performance gains in games is not a lot if anything at all.Is this a good thing ? Can you not just use 3 cables I'm not O/C this card..
It is challenging to make it look neat. I've got the official Corsair cable on the way.That cable is a mess not looking forward to that lol. But once i see my frames rocket it won't be a issue lol
My card is gonna be on a riser cable,It is challenging to make it look neat. I've got the official Corsair cable on the way.
Hell no, cablemods all the way.How many of use are using the nvidia cable for your 4090
Being turned into a mini-game apparently instead of a tech demo and released March-ish.What ever happened to that RTX racer demo? Only thing I can see is it was supposed to be released in November?
Why do some of these 12VHPWR Cable have 3 connectors.?
I'm using it have been since the day after launch day i have no plans to replace it.How many of use are using the nvidia cable for your 4090
Where's all the 4090s at? Some of that data is broken? Apparently 3060 ownership dropped by 2% in one month.
I was the same, I wanted an ATX 3.0 PSU but ended up just getting an Antec 1300w ATX 2.4? supply that was way cheaper than the ATX 3 supplies are going to be.Was gonna pull the trigger on a 4090 but I need a new psu and none available anywhere
Will wait till they come back in stock and order both together
That's actually quite neat. Not having tonnes of RGB in there also just keeps it functional rather than form. Best I've seen with the 3/4 way adapter.It is challenging to make it look neat. I've got the official Corsair cable on the way.
