No stress, I didn't get round to updating today. The date is based on what I saw on system information. I assumed it was version date but it must refer to something else if it doesn't matchYou are doing something wrong with your bios ??
check here : https://www.msi.com/Motherboard/MAG-X570-TOMAHAWK-WIFI/support
There is no 23.06.2021 version
Are you on X570S ?
Is 7C84v1B a beta version?I am on the latest bios, 7C84v1B dated 2022-08-30 on MSI web page.
CPUZ says date of bios is 08/11/2022.
Id be testing that drive in another system / the primary slot on the board to confirm if the SSD is good or not.Has anyone had any problems using the secondary NVME slot of the chipset on this motherboard?
Just tried to install a Netac NV7000 2tb in the secondary slot (unclear if it was the phison or innogrit model).
Doing so resulted in a complete inability of the system to respond to the power button.
Taking the drive out resulted in the same.
Clearing the CMOS with the drive out, and hitting Power got me back to a normal boot.
Putting the drive back resulted in complete inability to respond to the power button.
Clearing the CMOS after the drive was installed resulted in complete inability to respond to the power button.
Taking the drive out, clearing the CMOS with the drive out, and hitting Power got me back to a normal boot.
Does this look like a quirk of the motherboard, or is it 'typical' of a defective SSD?
Many thanks. PgT
Anything of note added by this updated?
ITs always such a pain re-doing all BIOS settings after an upgrade that I am loathed to bother.
I am sure my old Z97m had a better update process, as the settings where retained if you did so via windows. (I think... memory might be hazy)
If it aint broke don't fix it
I go through the latest BIOS's whilst i'm still configuring (RAM oc usually) but once i'm settled and using it for a while, that's it. I'll only update now if there's an issue worth solving with it.
Last bios is out of beta !
- Description:
- Patch Potential Security Vulnerabilities of AMD Ryzen CPUs
