Teed off and left tails for another small radiator in the kitchen. The builders plumber obviously doesn't know his left from right or flow from return so the TRV on this rad will need to go on the RHS
I should have really checked myself but just took his word/markings for it.
Wasn't able to bury a standard elbow deep enough in the floor for it to sit below finished floor level so quickly soldered some elbows to some offcuts and used a straight coupler instead.
T+G flooring will be laid once the builders have added a thin self levelling to match the existing plywood seen on the left, so can be got at if ever really needed without too much trouble.
My second hand £30 wall chaser coming in handy to knock out a 40mm channel which houses two runs of 15mm pipe quite nicely.
